I do have a successful running caldav google calendar setup to manage my waste. I got an ical yearly import from my community department which I have loaded into my google calendar.
Basically I am only interested to display the subject line in Habpanel. However when I look into my openhab logs I do see this :
2020-04-26 11:00:40.089 [ERROR] [org.openhab.io.caldav.EventUtils ] - invalid format for line: Papier nicht vergessen!
2020-04-26 11:00:40.113 [ERROR] [org.openhab.io.caldav.EventUtils ] - invalid format for line: Gelbe Säcke nicht vergessen!
2020-04-26 11:00:40.116 [ERROR] [org.openhab.io.caldav.EventUtils ] - invalid format for line: Bio nicht vergessen!
2020-04-26 11:00:40.180 [ERROR] [org.openhab.io.caldav.EventUtils ] - invalid format for line: Hausmüll nicht vergessen!
Any idea what to change. Is it around the German “umlaut” äüö ? or is it the exclamation mark at the end of the body text “!” …
I can’t see anything special when going to google and edit such an event…
don’t understand why you recommending to uninstall. the calendar functionality is actually working.
I am just struggling to understand why I do get this EventUtils line errors in the log files and how to potentially diagnose/fix it.
Meanwhile I have exported my calendar entries and this below is an iCal extract of one event causing an error. it looks pretty ok to me. So question is why this is generating an “invalid format for line: Gelbe Säcke nicht vergessen!” error…
perhaps this below helps to digagnose more. Does somebody know what Sardine-5.6.jar file is doing. I am unfortunatelly not a java expert/developper…
Any help apprechiated.
2020-04-30 07:00:12.965 [WARN ] [caldav.internal.job.EventReloaderJob] - Sardine exception reading ics file: 6583b4e116d390bd91305926d79faa5f
com.github.sardine.impl.SardineException: Unexpected response
at com.github.sardine.impl.handler.ValidatingResponseHandler.validateResponse(ValidatingResponseHandler.java:48) ~[sardine-5.6.jar:5.6]
at com.github.sardine.impl.handler.VoidResponseHandler.handleResponse(VoidResponseHandler.java:34) ~[sardine-5.6.jar:5.6]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:756) ~[sardine-5.6.jar:5.6]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:741) ~[sardine-5.6.jar:5.6]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:732) ~[sardine-5.6.jar:5.6]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:145) ~[sardine-5.6.jar:5.6]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:323) [bundleFile:?]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:141) [bundleFile:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
2020-04-30 07:02:55.415 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: b43449c884bb581d1d28c8e041f0640d(Gelbe Säcke@30.04.2020/00:00-01.05.2020/00:00)
2020-04-30 07:02:55.416 [ERROR] [org.openhab.io.caldav.EventUtils ] - invalid format for line: Gelbe Säcke nicht vergessen!
