Caldav Problems
Hi Guys,
are there still Problems with the caldav binding on OH 2.2.0?
I have the folder Muell (path: /var/lib/openhab2/etc/caldav/Muell) filled with ics Files but the caldav binding could not find the Folder.
2018-03-13 07:39:47.485 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[Muell], from=2018-03-13T07:39:47.340+01:00, to=null, sort=ASCENDING, filterName=null] with 0 entries
2018-03-13 07:39:47.491 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[Muell], from=2018-03-13T07:39:47.239+01:00, to=null, sort=ASCENDING, filterName=null] with 0 entries
2018-03-13 07:39:47.494 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - calendar id Muell not found
2018-03-13 07:39:47.496 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[Muell], from=2018-03-13T07:39:47.493+01:00, to=null, sort=null, filterName=null] with 0 entries
2018-03-13 07:39:47.496 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - calendar id Muell not found
2018-03-13 07:39:47.502 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[Muell], from=2018-03-13T07:39:47.496+01:00, to=null, sort=ASCENDING, filterName=null] with 0 entries
2018-03-13 07:39:47.507 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - calendar id Muell not found
Install over the addons Folder without Paper UI didn“t work also.
I tried to clean the Cache, but when i delete the content of Cache and tmp, OH has no bindings anymore.
i hope you can help me.
best regards
vaillan
Can you post your caldavio.cfg and caldavCommand.cfg please?
ok, sorry.
I checked my config 100 times so i assumed that there has to be a binding Problem.:wink:
So i hope there is no config failure, that would be very embarrassing.:blush:
caldavio.cfg:
caldavio:Muell:url=https://www.google.com/calendar/dav/calenderid@group.calendar.google.com/events
caldavio:Muell:username=email adress
caldavio:Muell:password=pwd
caldavio:Muell:reloadInterval=60
caldavio:Muell:preloadTime=2880
caldavPersonal.cfg
caldavPersonal:usedCalendars=Muell
caldavCommand.cfg
caldavCommand:readCalendars=Muell
best regards
vaillan
The caldavio:username=emailaddress
Remove the @gmail.com and only use the first part of the email address
The Connection to the Google calender works, it“s not an authentication Problem - it is possible to Login with email or username.
But i found the Problem.
It seems that, changing the config in the Services Folder does not overwrite the binding config.
So i had some wrong config Parameters in the /var/lib/openhab2/config/org/openhab config file.
Now i cleared up the wrong Parameters in the config file and get a different error:
2018-03-13 12:17:07.315 [DEBUG] [caldav.internal.job.EventReloaderJob] - Processing event ā€˜Restabfallbehaelter’
2018-03-13 12:17:07.318 [DEBUG] [caldav.internal.job.EventReloaderJob] - No periods exist for event ā€˜Restabfallbehaelter’
2018-03-13 12:17:07.324 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - event is already in event map and newer → delete the old one, reschedule timer
2018-03-13 12:17:07.336 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[Muell], from=2018-03-13T12:17:07.335+01:00, to=null, sort=null, filterName=null] with 1 entries
2018-03-13 12:17:07.339 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[Muell], from=2018-03-13T12:17:07.339+01:00, to=null, sort=ASCENDING, filterName=null] with 1 entries
Here is my items config:
String 		CalendarName1		   	"Tonne [%s]"  								<calendar>	{ caldavPersonal="calendar:Muell type:Event eventNr:1 value:NAME" }
DateTime    CalendarTimeStart1		"Datum der Abholung [%1$td.%1$tm.%1$tY]"    <calendar>	{ caldavPersonal="calendar:Muell type:Event eventNr:1 value:START" }
DateTime    CalendarTimeEnd1		"Datum der Abholung [%1$td.%1$tm.%1$tY]"    <calendar>	{ caldavPersonal="calendar:Muell type:Event eventNr:1 value:END" }
Hope you have a solution for me
Vaillan
Try changing the preload time to 1439 (1 minute less than a day)
I had problems too with repeat events before and that solved it
Maybe that’s it
Change the preload time
caldavio:Muell:preloadTime=1439
and restart openHAB
the preloadtime was also my assumption - i had not enough Meetings in my calender.
I set the preloadtime to 18720 now it works.
puhh this was hard work to get it done.
Here is my Problem summary with the Solutions:
1.Problem:
               401 authentication Error with the Google calender.
Solution:
               You have to enable unsecure Apps at your Google account otherwise Google will
               block caldav Connection.
  1. Problem:
               org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned
               a null service object
Solution:
              Compare the addon config in the Services Folder with the config in
              the /var/lib/openhab2/config/org/openhab Folder
thx for help
Vaillan
