misko903
(Miso K)
September 14, 2021, 7:45am
1
Hello guys,
I have rule to create a mp4 file, which is sent through Telegram to my phone. On 2 different ONVIF cameras, one is working, second one only as GIF.
What I am doing wrong?
rule "zvoncek-mp4-telegram.schody.mp4"
Channel "mihome:sensor_switch:286c0785f092:158d0001243994:button" triggered SHORT_PRESSED //testovacie tlacidlo
//Start creating the MP4
getActions("ipcamera", "ipcamera:onvif:02af0621db").recordGIF("ipcamera",5)
getActions("ipcamera", "ipcamera:onvif:02af0621db").recordMP4("ipcamera",5)
rule "zvoncek-mp4-telegram.schody.posli_na_telegram"
Item CamVchod_MP4Recording changed to 0 //rucne vytvoreny CamVchod_MP4Recording Item.
logInfo("zvoncek-mp4-telegram.schody.posli_na_telegram", "skusim poslat spravu")
val telegramAction = getActions("telegram","telegram:telegramBot:e13f59dd1f")
telegramAction.sendTelegramAnimation("file:///etc/openhab/html/camera1/ipcamera.mp4", "Niekto zvonĂ na schodoch")
CamVchod thing
UID: ipcamera:onvif:02af0621db
label: CamVchod
thingTypeUID: ipcamera:onvif
configuration:
mjpegOptions: -q:v 5 -r 2 -vf scale=640:-2 -update 1
ipAddress: 192.168.1.55
updateImageWhen: "0"
onvifPort: 8899
gifPreroll: 5
ffmpegLocation: /usr/bin/ffmpeg
serverPort: 8211
ffmpegOutput: /etc/openhab/html/camera1/
ipWhitelist: DISABLE
mp4OutOptions: -c:v copy -c:a copy
pollTime: 1000
password: *****
port: 80
snapshotUrl: http://192.168.1.55/tmpfs/auto.jpg
snapshotOptions: -an -vsync vfr -q:v 2 -update 1
ptzContinuous: false
onvifMediaProfile: 0
username: admin
hlsOutOptions: -strict -2 -f lavfi -i aevalsrc=0 -acodec aac -vcodec copy
-hls_flags delete_segments -hls_time 2 -hls_list_size 4
gifOutOptions: -r 2 -filter_complex
scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse
CamVchod_MP4Recording .item
tail -f says the file is empty , I checked in FS and it is updated, but 0b size :
2021-09-14 09:42:53.092 [INFO ] [.core.model.script.test_button.rules] - Short pressed
2021-09-14 09:42:53.090 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mihome:sensor_switch:286c0785f092:158d0001243994:button triggered SHORT_PRESSED
2021-09-14 09:42:53.295 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CamVchod_MP4Recording' changed from 0 to 5
2021-09-14 09:42:58.438 [INFO ] [p4-telegram.schody.posli_na_telegram] - skusim poslat spravu
2021-09-14 09:42:58.486 [WARN ] [gram.internal.action.TelegramActions] - Failed to send telegram message: Bad Request: file must be non-empty
2021-09-14 09:42:58.432 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CamVchod_MP4Recording' changed from 5 to 0
I am trying to sort it out few days, no results…
Thanks!
matt1
(Skinah)
September 14, 2021, 1:04pm
2
Debug logs, see very start of ipcamera docs, title is what to do if you need help.
misko903
(Miso K)
September 14, 2021, 1:31pm
3
ok, so I disabled the other 2 cameras and ran the console with
TRACE org.openhab.binding.ipcamera
this is the result. I dont know more now
2021-09-14 15:24:36.796 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-09-14 15:24:36.890 [DEBUG] [ng.ipcamera.internal.IpCameraActions] - Recording ipcamera.mp4 for 5 seconds.
2021-09-14 15:24:36.890 [INFO ] [.core.model.script.test_button.rules] - Short pressed
2021-09-14 15:24:36.892 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Starting ffmpeg with this command now:-y -t 5 -hide_banner -loglevel warning -rtsp_transport tcp -i rtsp://admin:********@192.168.1.55:554/12 -c:v copy -c:a copy /etc/openhab/html/camera2/ipcamera.mp4
2021-09-14 15:24:36.885 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mihome:sensor_switch:286c0785f092:158d0001243994:button triggered SHORT_PRESSED
2021-09-14 15:24:36.898 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CamVchod_MP4Recording' changed from 0 to 5
2021-09-14 15:24:37.831 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.51/onvif/Events</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">F/86Kd9xPWp8wDjwJGeMuigkABE=</wsse:Password><wsse:Nonce>MTc4NzI5OTc1NQ==</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-09-14T14:24:41Z</tev:CurrentTime><tev:TerminationTime>2021-09-14T14:29:41Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-09-14T15:24:41Z" PropertyOperation="Changed">
<tt:Source>
<tt:SimpleItem Name="VideoSourceConfigurationToken" Value="000" />
<tt:SimpleItem Name="VideoAnalyticsConfigurationToken" Value="000" />
<tt:SimpleItem Name="Rule" Value="MyMotionDetectorRule" />
</tt:Source>
<tt:Data>
<tt:SimpleItem Name="IsMotion" Value="false" />
</tt:Data>
</tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:37.833 [DEBUG] [amera.internal.onvif.OnvifConnection] - Onvif Event Topic:RuleEngine/CellMotionDetector/Motion, Data:IsMotion, Value:false
2021-09-14 15:24:37.834 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler IpCameraHandler of thing ipcamera:onvif:34aaa0d217 tried updating channel cellMotionAlarm although the handler was already disposed.
2021-09-14 15:24:37.836 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-09-14 15:24:38.555 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.53/onvif/Events_PullSubManager_2021-09-14T02:17:56Z_0</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">OpgUrZ5x6Ol9GsWrSjKaCFSUQHA=</wsse:Password><wsse:Nonce>NzAxNjQ3NzMz</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-09-14T14:24:40Z</tev:CurrentTime><tev:TerminationTime>2021-09-14T14:29:40Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-09-14T15:24:40Z" PropertyOperation="Changed">
<tt:Source>
</tt:Source>
<tt:Data>
</tt:Data>
2021-09-14 15:24:38.557 [DEBUG] [amera.internal.onvif.OnvifConnection] - Onvif Event Topic:RuleEngine/CellMotionDetector/Motion, Data:IsMotion, Value:false
2021-09-14 15:24:38.558 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler IpCameraHandler of thing ipcamera:onvif:18a7bab32a tried updating channel cellMotionAlarm although the handler was already disposed.
2021-09-14 15:24:38.560 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-09-14 15:24:38.871 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.51/onvif/Events_PullSubManager_2021-09-14T01:26:33Z_0</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">Toy6/McQgD/H9JcHhyNZ1NJVZSA=</wsse:Password><wsse:Nonce>LTE4Mjc2NjQ5NzE=</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-09-14T14:24:42Z</tev:CurrentTime><tev:TerminationTime>2021-09-14T14:29:42Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-09-14T15:24:42Z" PropertyOperation="Changed">
<tt:Source>
</tt:Source>
<tt:Data>
</tt:Data>
2021-09-14 15:24:38.873 [DEBUG] [amera.internal.onvif.OnvifConnection] - Onvif Event Topic:RuleEngine/CellMotionDetector/Motion, Data:IsMotion, Value:false
2021-09-14 15:24:38.875 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler IpCameraHandler of thing ipcamera:onvif:34aaa0d217 tried updating channel cellMotionAlarm although the handler was already disposed.
2021-09-14 15:24:38.876 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-09-14 15:24:39.632 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.53/onvif/Events_PullSubManager_2021-09-14T02:17:56Z_0</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">s4ZeHnPfl+fgGwe1Mx7rSqGNZks=</wsse:Password><wsse:Nonce>MTI4NjMyOTgy</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-09-14T14:25:42Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-09-14T14:24:42Z</wsnt:CurrentTime></wsnt:RenewResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:39.634 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-09-14 15:24:39.940 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">xk17vxYCKiCs+vVl8sUHXQDOGSU=</wsse:Password><wsse:Nonce>MzEzODA1MDIz</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetStatusResponse><tptz:PTZStatus><tt:Position><tt:PanTilt y="0" x="0"></tt:PanTilt><tt:Zoom x="0"></tt:Zoom></tt:Position><tt:MoveStatus><tt:PanTilt>IDLE</tt:PanTilt><tt:Zoom>IDLE</tt:Zoom></tt:MoveStatus><tt:UtcTime>1970-01-01T00:00:00Z</tt:UtcTime></tptz:PTZStatus></tptz:GetStatusResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:39.942 [DEBUG] [amera.internal.onvif.OnvifConnection] - Processing new PTZ location now
2021-09-14 15:24:39.943 [DEBUG] [amera.internal.onvif.OnvifConnection] - Pan is updating to:50 and the cam value is 0.0
2021-09-14 15:24:39.945 [DEBUG] [amera.internal.onvif.OnvifConnection] - Tilt is updating to:50 and the cam value is 0.0
2021-09-14 15:24:39.946 [DEBUG] [amera.internal.onvif.OnvifConnection] - Zoom is updating to:0 and the cam value is 0.0
2021-09-14 15:24:39.967 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">HrZSHa5j00HshpyqcfdeBlnMU4g=</wsse:Password><wsse:Nonce>NjI0MTMyMjAz</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetConfigurationsResponse><tptz:PTZConfiguration token="000"><tt:Name>PTZ_000</tt:Name><tt:UseCount>2</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" y="1" x="1"></tt:PanTilt><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="1"></tt:Zoom></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT1S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tptz:PTZConfiguration></tptz:GetConfigurationsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:39.968 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2021-09-14 15:24:39.970 [DEBUG] [amera.internal.onvif.OnvifConnection] - ptzConfigToken=000
2021-09-14 15:24:39.972 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurationOptions
2021-09-14 15:24:40.006 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Guessed Channel Layout for Input Stream #0.1 : mono
2021-09-14 15:24:40.007 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [mp4 @ 0xeff3b0] Could not find tag for codec pcm_alaw in stream #1, codec not currently supported in container
2021-09-14 15:24:40.008 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
2021-09-14 15:24:40.009 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] -
2021-09-14 15:24:40.044 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.51/onvif/Events</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">qN3vbOpxOL0Vt0JLitD8DMf/cys=</wsse:Password><wsse:Nonce>MTI3OTMxOTM0Nw==</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:CreatePullPointSubscriptionResponse><tev:SubscriptionReference><wsa5:Address>http://192.168.1.51:8899/onvif/Events_PullSubManager_2021-09-14T14:24:44Z_0</wsa5:Address></tev:SubscriptionReference><wsnt:CurrentTime>2021-09-14T14:24:44Z</wsnt:CurrentTime><wsnt:TerminationTime>2021-09-14T14:34:44Z</wsnt:TerminationTime></tev:CreatePullPointSubscriptionResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:40.045 [DEBUG] [amera.internal.onvif.OnvifConnection] - subscriptionXAddr=/onvif/Events_PullSubManager_2021-09-14T14:24:44Z_0
2021-09-14 15:24:40.045 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-09-14 15:24:40.077 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.51/onvif/Events</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">fjujw6f+op3vCqk1wkCbwqyVdNI=</wsse:Password><wsse:Nonce>LTEzMDY0Mzc5MDU=</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-09-14T14:25:44Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-09-14T14:24:44Z</wsnt:CurrentTime></wsnt:RenewResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:40.078 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-09-14 15:24:40.118 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.51/onvif/Events</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">fTjO+NrRqDkyE3JsszgsrFzC5N4=</wsse:Password><wsse:Nonce>LTc5NjcwNTM3NA==</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-09-14T14:25:44Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-09-14T14:24:44Z</wsnt:CurrentTime></wsnt:RenewResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
misko903
(Miso K)
4
2021-09-14 15:24:40.119 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-09-14 15:24:40.152 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.51/onvif/Events_PullSubManager_2021-09-14T01:26:33Z_0</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">Cdq8N4mpGNsc5qDQgYe0EvF9cXs=</wsse:Password><wsse:Nonce>MjEyMDUwNzE0Mw==</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-09-14T14:25:44Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-09-14T14:24:44Z</wsnt:CurrentTime></wsnt:RenewResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:40.153 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-09-14 15:24:40.836 [INFO ] [p4-telegram.schody.posli_na_telegram] - skusim poslat spravu
2021-09-14 15:24:40.883 [WARN ] [gram.internal.action.TelegramActions] - Failed to send telegram message: Bad Request: file must be non-empty
2021-09-14 15:24:40.831 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'CamVchod_MP4Recording' changed from 5 to 0
2021-09-14 15:24:41.233 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">a4ElMzOOizgi//P8GC7XXuH4KAY=</wsse:Password><wsse:Nonce>LTE0MjQ3MTAzMzk=</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetPresetsResponse><tptz:Preset token="0"><tt:Name>0</tt:Name></tptz:Preset><tptz:Preset token="1"><tt:Name>1</tt:Name></tptz:Preset><tptz:Preset token="2"><tt:Name>2</tt:Name></tptz:Preset><tptz:Preset token="3"><tt:Name>3</tt:Name></tptz:Preset><tptz:Preset token="4"><tt:Name>4</tt:Name></tptz:Preset><tptz:Preset token="5"><tt:Name>5</tt:Name></tptz:Preset><tptz:Preset token="6"><tt:Name>6</tt:Name></tptz:Preset><tptz:Preset token="7"><tt:Name>7</tt:Name></tptz:Preset><tptz:Preset token="8"><tt:Name>8</tt:Name></tptz:Preset><tptz:Preset token="9"><tt:Name>9</tt:Name></tptz:Preset><tptz:Preset token="10"><tt:Name>10</tt:Name></tptz:Preset><tptz:Preset token="11"><tt:Name>11</tt:Name></tptz:Preset><tptz:Preset token="12"><tt:Name>12</tt:Name></tptz:Preset><tptz:Preset token="13"><tt:Name>13</tt:Name></tptz:Preset><tptz:Preset token="14"><tt:Name>14</tt:Name></tptz:Preset><tptz:Preset token="15"><tt:Name>15</tt:Name></tptz:Preset><tptz:Preset token="16"><tt:Name>16</tt:Name></tptz:Preset><tptz:Preset token="17"><tt:Name>17</tt:Name></tptz:Preset><tptz:Preset token="18"><tt:Name>18</tt:Name></tptz:Preset><tptz:Preset token="19"><tt:Name>19</tt:Name></tptz:Preset><tptz:Preset token="20"><tt:Name>20</tt:Name></tptz:Preset><tptz:Preset token="21"><tt:Name>21</tt:Name></tptz:Preset><tptz:Preset token="22"><tt:Name>22</tt:Name></tptz:Preset><tptz:Preset token="23"><tt:Name>23</tt:Name></tptz:Preset><tptz:Preset token="24"><tt:Name>24</tt:Name></tptz:Preset><tptz:Preset token="25"><tt:Name>25</tt:Name></tptz:Preset><tptz:Preset token="26"><tt:Name>26</tt:Name></tptz:Preset><tptz:Preset token="27"><tt:Name>27</tt:Name></tptz:Preset><tptz:Preset token="28"><tt:Name>28</tt:Name></tptz:Preset><tptz:Preset token="29"><tt:Name>29</tt:Name></tptz:Preset><tptz:Preset token="30"><tt:Name>30</tt:Name></tptz:Preset><tptz:Preset token="31"><tt:Name>31</tt:Name></tptz:Preset><tptz:Preset token="32"><tt:Name>32</tt:Name></tptz:Preset><tptz:Preset token="33"><tt:Name>33</tt:Name></tptz:Preset><tptz:Preset token="34"><tt:Name>34</tt:Name></tptz:Preset><tptz:Preset token="35"><tt:Name>35</tt:Name></tptz:Preset><tptz:Preset token="36"><tt:Name>36</tt:Name></tptz:Preset><tptz:Preset token="37"><tt:Name>37</tt:Name></tptz:Preset><tptz:Preset token="38"><tt:Name>38</tt:Name></tptz:Preset><tptz:Preset token="39"><tt:Name>39</tt:Name></tptz:Preset><tptz:Preset token="40"><tt:Name>40</tt:Name></tptz:Preset><tptz:Preset token="41"><tt:Name>41</tt:Name></tptz:Preset><tptz:Preset token="42"><tt:Name>42</tt:Name></tptz:Preset><tptz:Preset token="43"><tt:Name>43</tt:Name></tptz:Preset><tptz:Preset token="44"><tt:Name>44</tt:Name></tptz:Preset><tptz:Preset token="45"><tt:Name>45</tt:Name></tptz:Preset><tptz:Preset token="46"><tt:Name>46</tt:Name></tptz:Preset><tptz:Preset token="47"><tt:Name>47</tt:Name></tptz:Preset><tptz:Preset token="48"><tt:Name>48</tt:Name></tptz:Preset><tptz:Preset token="49"><tt:Name>49</tt:Name></tptz:Preset><tptz:Preset token="50"><tt:Name>50</tt:Name></tptz:Preset><tptz:Preset token="51"><tt:Name>51</tt:Name></tptz:Preset><tptz:Preset token="52"><tt:Name>52</tt:Name></tptz:Preset><tptz:Preset token="53"><tt:Name>53</tt:Name></tptz:Preset><tptz:Preset token="54"><tt:Name>54</tt:Name></tptz:Preset><tptz:Preset token="55"><tt:Name>55</tt:Name></tptz:Preset><tptz:Preset token="56"><tt:Name>56</tt:Name></tptz:Preset><tptz:Preset token="57"><tt:Name>57</tt:Name></tptz:Preset><tptz:Preset token="58"><tt:Name>58</tt:Name></tptz:Preset><tptz:Preset token="59"><tt:Name>59</tt:Name></tptz:Preset><tptz:Preset token="60"><tt:Name>60</tt:Name></tptz:Preset><tptz:Preset token="61"><tt:Name>61</tt:Name></tptz:Preset><tptz:Preset token="62"><tt:Name>62</tt:Name></tptz:Preset><tptz:Preset token="63"><tt:Name>63</tt:Name></tptz:Preset><tptz:Preset token="64"><tt:Name>64</tt:Name></tptz:Preset><tptz:Preset token="65"><tt:Name>65</tt:Name></tptz:Preset><tptz:Preset token="66"><tt:Name>66</tt:Name></tptz:Preset><tptz:Preset token="67"><tt:Name>67</tt:Name></tptz:Preset><tptz:Preset token="68"><tt:Name>68</tt:Name></tptz:Preset><tptz:Preset token="69"><tt:Name>69</tt:Name></tptz:Preset><tptz:Preset token="70"><tt:Name>70</tt:Name></tptz:Preset><tptz:Preset token="71"><tt:Name>71</tt:Name></tptz:Preset><tptz:Preset token="72"><tt:Name>72</tt:Name></tptz:Preset><tptz:Preset token="73"><tt:Name>73</tt:Name></tptz:Preset><tptz:Preset token="74"><tt:Name>74</tt:Name></tptz:Preset><tptz:Preset token="75"><tt:Name>75</tt:Name></tptz:Preset><tptz:Preset token="76"><tt:Name>76</tt:Name></tptz:Preset><tptz:Preset token="77"><tt:Name>77</tt:Name></tptz:Preset><tptz:Preset token="78"><tt:Name>78</tt:Name></tptz:Preset><tptz:Preset token="79"><tt:Name>79</tt:Name></tptz:Preset><tptz:Preset token="80"><tt:Name>80</tt:Name></tptz:Preset><tptz:Preset token="81"><tt:Name>81</tt:Name></tptz:Preset><tptz:Preset token="82"><tt:Name>82</tt:Name></tptz:Preset><tptz:Preset token="83"><tt:Name>83</tt:Name></tptz:Preset><tptz:Preset token="84"><tt:Name>84</tt:Name></tptz:Preset><tptz:Preset token="85"><tt:Name>85</tt:Name></tptz:Preset><tptz:Preset token="86"><tt:Name>86</tt:Name></tptz:Preset><tptz:Preset token="87"><tt:Name>87</tt:Name></tptz:Preset><tptz:Preset token="88"><tt:Name>88</tt:Name></tptz:Preset><tptz:Preset token="89"><tt:Name>89</tt:Name></tptz:Preset><tptz:Preset token="90"><tt:Name>90</tt:Name></tptz:Preset><tptz:Preset token="91"><tt:Name>91</tt:Name></tptz:Preset><tptz:Preset token="92"><tt:Name>92</tt:Name></tptz:Preset><tptz:Preset token="93"><tt:Name>93</tt:Name></tptz:Preset><tptz:Preset token="94"><tt:Name>94</tt:Name></tptz:Preset><tptz:Preset token="95"><tt:Name>95</tt:Name></tptz:Preset><tptz:Preset token="96"><tt:Name>96</tt:Name></tptz:Preset><tptz:Preset token="97"><tt:Name>97</tt:Name></tptz:Preset><tptz:Preset token="98"><tt:Name>98</tt:Name></tptz:Preset><tptz:Preset token="99"><tt:Name>99</tt:Name></tptz:Preset><tptz:Preset token="100"><tt:Name>100</tt:Name></tptz:Preset><tptz:Preset token="101"><tt:Name>101</tt:Name></tptz:Preset><tptz:Preset token="102"><tt:Name>102</tt:Name></tptz:Preset><tptz:Preset token="103"><tt:Name>103</tt:Name></tptz:Preset><tptz:Preset token="104"><tt:Name>104</tt:Name></tptz:Preset><tptz:Preset token="105"><tt:Name>105</tt:Name></tptz:Preset><tptz:Preset token="106"><tt:Name>106</tt:Name></tptz:Preset><tptz:Preset token="107"><tt:Name>107</tt:Name></tptz:Preset><tptz:Preset token="108"><tt:Name>108</tt:Name></tptz:Preset><tptz:Preset token="109"><tt:Name>109</tt:Name></tptz:Preset><tptz:Preset token="110"><tt:Name>110</tt:Name></tptz:Preset><tptz:Preset token="111"><tt:Name>111</tt:Name></tptz:Preset><tptz:Preset token="112"><tt:Name>112</tt:Name></tptz:Preset><tptz:Preset token="113"><tt:Name>113</tt:Name></tptz:Preset><tptz:Preset token="114"><tt:Name>114</tt:Name></tptz:Preset><tptz:Preset token="115"><tt:Name>115</tt:Name></tptz:Preset><tptz:Preset token="116"><tt:Name>116</tt:Name></tptz:Preset><tptz:Preset token="117"><tt:Name>117</tt:Name></tptz:Preset><tptz:Preset token="118"><tt:Name>118</tt:Name></tptz:Preset><tptz:Preset token="119"><tt:Name>119</tt:Name></tptz:Preset><tptz:Preset token="120"><tt:Name>120</tt:Name></tptz:Preset><tptz:Preset token="121"><tt:Name>121</tt:Name></tptz:Preset><tptz:Preset token="122"><tt:Name>122</tt:Name></tptz:Preset><tptz:Preset token="123"><tt:Name>123</tt:Name></tptz:Preset><tptz:Preset token="124"><tt:Name>124</tt:Name></tptz:Preset><tptz:Preset token="125"><tt:Name>125</tt:Name></tptz:Preset><tptz:Preset token="126"><tt:Name>126</tt:Name></tptz:Preset></tptz:GetPresetsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:41.236 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:0
2021-09-14 15:24:41.237 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:1
2021-09-14 15:24:41.239 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:2
2021-09-14 15:24:41.240 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:3
2021-09-14 15:24:41.241 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:4
2021-09-14 15:24:41.242 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:5
2021-09-14 15:24:41.243 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:6
2021-09-14 15:24:41.244 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:7
2021-09-14 15:24:41.245 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:8
2021-09-14 15:24:41.246 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:9
2021-09-14 15:24:41.246 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:10
2021-09-14 15:24:41.247 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:11
2021-09-14 15:24:41.248 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:12
2021-09-14 15:24:41.249 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:13
2021-09-14 15:24:41.250 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:14
2021-09-14 15:24:41.251 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:15
2021-09-14 15:24:41.252 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:16
2021-09-14 15:24:41.253 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:17
2021-09-14 15:24:41.254 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:18
2021-09-14 15:24:41.254 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:19
2021-09-14 15:24:41.255 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:20
2021-09-14 15:24:41.256 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:21
2021-09-14 15:24:41.257 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:22
2021-09-14 15:24:41.258 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:23
2021-09-14 15:24:41.259 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:24
2021-09-14 15:24:41.260 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:25
2021-09-14 15:24:41.260 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:26
2021-09-14 15:24:41.261 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:27
2021-09-14 15:24:41.262 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:28
2021-09-14 15:24:41.262 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:29
2021-09-14 15:24:41.263 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:30
2021-09-14 15:24:41.264 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:31
2021-09-14 15:24:41.264 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:32
2021-09-14 15:24:41.265 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:33
2021-09-14 15:24:41.266 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:34
2021-09-14 15:24:41.266 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:35
2021-09-14 15:24:41.267 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:36
2021-09-14 15:24:41.268 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:37
2021-09-14 15:24:41.268 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:38
2021-09-14 15:24:41.269 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:39
2021-09-14 15:24:41.269 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:40
2021-09-14 15:24:41.270 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:41
2021-09-14 15:24:41.271 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:42
2021-09-14 15:24:41.271 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:43
2021-09-14 15:24:41.272 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:44
2021-09-14 15:24:41.272 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:45
2021-09-14 15:24:41.273 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:46
2021-09-14 15:24:41.274 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:47
2021-09-14 15:24:41.274 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:48
2021-09-14 15:24:41.275 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:49
2021-09-14 15:24:41.276 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:50
2021-09-14 15:24:41.276 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:51
2021-09-14 15:24:41.277 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:52
2021-09-14 15:24:41.277 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:53
2021-09-14 15:24:41.278 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:54
2021-09-14 15:24:41.279 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:55
2021-09-14 15:24:41.279 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:56
2021-09-14 15:24:41.280 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:57
2021-09-14 15:24:41.281 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:58
2021-09-14 15:24:41.281 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:59
2021-09-14 15:24:41.282 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:60
2021-09-14 15:24:41.282 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:61
2021-09-14 15:24:41.283 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:62
2021-09-14 15:24:41.284 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:63
2021-09-14 15:24:41.284 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:64
2021-09-14 15:24:41.285 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:65
2021-09-14 15:24:41.285 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:66
2021-09-14 15:24:41.286 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:67
2021-09-14 15:24:41.287 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:68
2021-09-14 15:24:41.287 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:69
2021-09-14 15:24:41.288 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:70
2021-09-14 15:24:41.288 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:71
2021-09-14 15:24:41.289 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:72
2021-09-14 15:24:41.290 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:73
2021-09-14 15:24:41.290 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:74
2021-09-14 15:24:41.291 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:75
2021-09-14 15:24:41.292 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:76
2021-09-14 15:24:41.292 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:77
2021-09-14 15:24:41.293 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:78
2021-09-14 15:24:41.293 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:79
2021-09-14 15:24:41.294 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:80
2021-09-14 15:24:41.295 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:81
2021-09-14 15:24:41.295 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:82
2021-09-14 15:24:41.296 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:83
2021-09-14 15:24:41.297 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:84
2021-09-14 15:24:41.297 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:85
2021-09-14 15:24:41.298 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:86
2021-09-14 15:24:41.298 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:87
2021-09-14 15:24:41.299 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:88
2021-09-14 15:24:41.300 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:89
2021-09-14 15:24:41.300 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:90
2021-09-14 15:24:41.301 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:91
2021-09-14 15:24:41.301 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:92
2021-09-14 15:24:41.302 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:93
2021-09-14 15:24:41.303 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:94
2021-09-14 15:24:41.303 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:95
2021-09-14 15:24:41.304 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:96
2021-09-14 15:24:41.305 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:97
2021-09-14 15:24:41.305 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:98
2021-09-14 15:24:41.306 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:99
2021-09-14 15:24:41.306 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:100
2021-09-14 15:24:41.307 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:101
2021-09-14 15:24:41.308 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:102
2021-09-14 15:24:41.308 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:103
2021-09-14 15:24:41.309 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:104
2021-09-14 15:24:41.309 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:105
2021-09-14 15:24:41.310 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:106
2021-09-14 15:24:41.311 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:107
2021-09-14 15:24:41.311 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:108
2021-09-14 15:24:41.312 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:109
2021-09-14 15:24:41.312 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:110
2021-09-14 15:24:41.313 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:111
2021-09-14 15:24:41.314 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:112
2021-09-14 15:24:41.315 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">5xSG10A6lNV21Yui3tHorAFMVx8=</wsse:Password><wsse:Nonce>LTk0NDk5MTE4MA==</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tptz:GetConfigurationOptionsResponse><tptz:PTZConfigurationOptions><tt:Spaces><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativeZoomTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>0</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:RelativeZoomTranslationSpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange><tt:YRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1</tt:Min><tt:Max>1</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>1</tt:Min><tt:Max>8</tt:Max></tt:XRange></tt:PanTiltSpeedSpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>1</tt:Min><tt:Max>8</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:Spaces><tt:PTZTimeout><tt:Min>PT1S</tt:Min><tt:Max>PT120S</tt:Max></tt:PTZTimeout></tptz:PTZConfigurationOptions></tptz:GetConfigurationOptionsResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
2021-09-14 15:24:41.316 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:113
2021-09-14 15:24:41.317 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:114
2021-09-14 15:24:41.317 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:115
2021-09-14 15:24:41.318 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:116
2021-09-14 15:24:41.319 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:117
2021-09-14 15:24:41.319 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:118
2021-09-14 15:24:41.320 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:119
2021-09-14 15:24:41.321 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:120
2021-09-14 15:24:41.321 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:121
2021-09-14 15:24:41.322 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:122
2021-09-14 15:24:41.323 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:123
2021-09-14 15:24:41.323 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:124
2021-09-14 15:24:41.324 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:125
2021-09-14 15:24:41.325 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:126
2021-09-14 15:24:41.325 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:0
2021-09-14 15:24:41.326 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:1
2021-09-14 15:24:41.326 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:2
2021-09-14 15:24:41.327 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:3
2021-09-14 15:24:41.328 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:4
2021-09-14 15:24:41.328 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:5
2021-09-14 15:24:41.329 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:6
2021-09-14 15:24:41.330 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:7
2021-09-14 15:24:41.330 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:8
2021-09-14 15:24:41.331 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:9
2021-09-14 15:24:41.331 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:10
2021-09-14 15:24:41.332 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:11
2021-09-14 15:24:41.333 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:12
2021-09-14 15:24:41.333 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:13
2021-09-14 15:24:41.334 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:14
2021-09-14 15:24:41.335 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:15
2021-09-14 15:24:41.335 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:16
2021-09-14 15:24:41.336 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:17
2021-09-14 15:24:41.337 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:18
2021-09-14 15:24:41.337 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:19
2021-09-14 15:24:41.338 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:20
2021-09-14 15:24:41.338 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:21
2021-09-14 15:24:41.339 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:22
2021-09-14 15:24:41.340 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:23
2021-09-14 15:24:41.340 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:24
2021-09-14 15:24:41.341 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:25
2021-09-14 15:24:41.342 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:26
2021-09-14 15:24:41.342 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:27
2021-09-14 15:24:41.343 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:28
2021-09-14 15:24:41.343 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:29
2021-09-14 15:24:41.344 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:30
2021-09-14 15:24:41.345 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:31
2021-09-14 15:24:41.345 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:32
2021-09-14 15:24:41.346 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:33
2021-09-14 15:24:41.347 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:34
2021-09-14 15:24:41.347 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:35
2021-09-14 15:24:41.348 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:36
2021-09-14 15:24:41.348 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:37
2021-09-14 15:24:41.349 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:38
2021-09-14 15:24:41.350 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:39
2021-09-14 15:24:41.350 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:40
2021-09-14 15:24:41.351 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:41
2021-09-14 15:24:41.351 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:42
2021-09-14 15:24:41.352 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:43
2021-09-14 15:24:41.353 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:44
2021-09-14 15:24:41.353 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:45
2021-09-14 15:24:41.354 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:46
2021-09-14 15:24:41.354 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:47
2021-09-14 15:24:41.355 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:48
2021-09-14 15:24:41.356 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:49
2021-09-14 15:24:41.356 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:50
2021-09-14 15:24:41.357 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:51
2021-09-14 15:24:41.357 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:52
2021-09-14 15:24:41.358 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:53
2021-09-14 15:24:41.359 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:54
2021-09-14 15:24:41.359 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:55
2021-09-14 15:24:41.360 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:56
2021-09-14 15:24:41.360 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:57
2021-09-14 15:24:41.361 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:58
2021-09-14 15:24:41.362 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:59
2021-09-14 15:24:41.362 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:60
2021-09-14 15:24:41.363 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:61
2021-09-14 15:24:41.363 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:62
2021-09-14 15:24:41.364 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:63
2021-09-14 15:24:41.365 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:64
2021-09-14 15:24:41.365 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:65
2021-09-14 15:24:41.366 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:66
2021-09-14 15:24:41.366 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:67
2021-09-14 15:24:41.367 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:68
2021-09-14 15:24:41.368 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:69
2021-09-14 15:24:41.368 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:70
2021-09-14 15:24:41.369 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:71
2021-09-14 15:24:41.369 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:72
2021-09-14 15:24:41.370 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:73
2021-09-14 15:24:41.371 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:74
2021-09-14 15:24:41.371 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:75
2021-09-14 15:24:41.372 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:76
2021-09-14 15:24:41.373 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:77
2021-09-14 15:24:41.373 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:78
2021-09-14 15:24:41.374 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:79
2021-09-14 15:24:41.374 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:80
2021-09-14 15:24:41.375 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:81
2021-09-14 15:24:41.376 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:82
2021-09-14 15:24:41.376 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:83
2021-09-14 15:24:41.377 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:84
2021-09-14 15:24:41.377 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:85
2021-09-14 15:24:41.378 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:86
2021-09-14 15:24:41.379 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:87
2021-09-14 15:24:41.379 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:88
2021-09-14 15:24:41.380 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:89
2021-09-14 15:24:41.381 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:90
2021-09-14 15:24:41.381 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:91
2021-09-14 15:24:41.382 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:92
2021-09-14 15:24:41.382 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:93
2021-09-14 15:24:41.383 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:94
2021-09-14 15:24:41.384 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:95
2021-09-14 15:24:41.384 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:96
2021-09-14 15:24:41.385 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:97
2021-09-14 15:24:41.385 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:98
2021-09-14 15:24:41.386 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:99
2021-09-14 15:24:41.386 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:100
2021-09-14 15:24:41.387 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:101
2021-09-14 15:24:41.388 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:102
2021-09-14 15:24:41.388 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:103
2021-09-14 15:24:41.389 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:104
2021-09-14 15:24:41.389 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:105
2021-09-14 15:24:41.390 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:106
2021-09-14 15:24:41.391 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:107
2021-09-14 15:24:41.391 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:108
2021-09-14 15:24:41.392 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:109
2021-09-14 15:24:41.392 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:110
2021-09-14 15:24:41.393 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:111
2021-09-14 15:24:41.394 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:112
2021-09-14 15:24:41.394 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:113
2021-09-14 15:24:41.395 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:114
2021-09-14 15:24:41.395 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:115
2021-09-14 15:24:41.396 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:116
2021-09-14 15:24:41.397 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:117
2021-09-14 15:24:41.397 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:118
2021-09-14 15:24:41.398 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:119
2021-09-14 15:24:41.399 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:120
2021-09-14 15:24:41.400 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:121
2021-09-14 15:24:41.401 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:122
2021-09-14 15:24:41.401 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:123
2021-09-14 15:24:41.402 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:124
2021-09-14 15:24:41.402 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:125
2021-09-14 15:24:41.403 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:126
2021-09-14 15:24:41.693 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2000/10/XMLSchema" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:ns1="http://www.w3.org/2005/05/xmlmime" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:ns7="http://docs.oasis-open.org/wsrf/r-2" xmlns:ns2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:dndl="http://www.onvif.org/ver10/network/wsdl/DiscoveryLookupBinding" xmlns:dnrd="http://www.onvif.org/ver10/network/wsdl/RemoteDiscoveryBinding" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:ns10="http://www.onvif.org/ver10/replay/wsdl" xmlns:ns11="http://www.onvif.org/ver10/search/wsdl" xmlns:ns13="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:ns14="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:ns15="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:ns16="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:ns17="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns18="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:ns19="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:ns20="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:ns21="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:ns22="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:ns3="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:ns4="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns5="http://www.onvif.org/ver10/display/wsdl" xmlns:ns8="http://www.onvif.org/ver10/receiver/wsdl" xmlns:ns9="http://www.onvif.org/ver10/recording/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:trt2="http://www.onvif.org/ver20/media/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tnsn="http://www.eventextension.com/2011/event/topics"><SOAP-ENV:Header><wsa5:To SOAP-ENV:mustUnderstand="true">http://192.168.1.53/onvif/Events_PullSubManager_2021-09-14T02:17:56Z_0</wsa5:To><wsse:Security><wsse:UsernameToken><wsse:Username>pi</wsse:Username><wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">tcCD3QH16l/y6V1dPVWMUc4Axkk=</wsse:Password><wsse:Nonce>MTI2NjY1NzM5Mg==</wsse:Nonce></wsse:UsernameToken></wsse:Security></SOAP-ENV:Header><SOAP-ENV:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-09-14T14:24:43Z</tev:CurrentTime><tev:TerminationTime>2021-09-14T14:29:43Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-09-14T15:24:43Z" PropertyOperation="Changed">
<tt:Source>
<tt:SimpleItem Name="VideoSourceConfigurationToken" Value="000" />
<tt:SimpleItem Name="VideoAnalyticsConfigurationToken" Value="000" />
<tt:SimpleItem Name="Rule" Value="MyMotionDetectorRule" />
</tt:Source>
<tt:Data>
<tt:SimpleItem Name="IsMotion" Value="false" />
</tt:Data>
</tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
matt1
(Skinah)
September 14, 2021, 9:52pm
5
misko903:
BTW these are lines from ffmpeg so doing a Google search on key parts will give you instant info and solutions as ffmpeg is used by many people not just openhab.
It would have been easier to find with debug level not trace. Trace gives way more detail.
Sounds like the camera is using an audio format that is not supported in a mp4 container. Does the camera allow you to change the audio format?
misko903
(Miso K)
September 16, 2021, 4:59am
6
yes, I can change it from G711 to G726. Anyway, I though it is a very common format.
EDIT: G726 is not working too, I switched it off and it is working now! But that means disabled audio on camera and syno recording… 1st camera stream - with audio: synology recording, 2nd camera stream - no audio: openHAB
matt1
(Skinah)
September 16, 2021, 9:16am
7
You can use ffmpeg arguments to convert the audio into one that is supported. However it is strange that AAC or mp3 are not options to choose? See ffmpeg website docs or google how to do it.
@misko903 if you work it out, can you post a short answer on how it was fixed and mark the thread as solved by your solution? This helps others that will find your post get an answer quicker.
I had the same problem with a camera whose audio/video are G711/H.264 and fixed it with:
