#Background:
I have been running a basic OpenHAB server for 6 months odd with 5 Lifx Lights and a load of rules to turn on/off the lights depending on who is awake/in/out of the house. We started getting issues with lights randomly coming on/off as the rules got complex and the console logging was/is hard to get enough info to debug (also limited in size and often gone by the time I get time to look) so I have decided to start again but this time logging all of the commands and states into a MySQL DB.
#What I have managed:
I have managed to install and setup a MySQL DB, install the “MySQL Persistance” (persistance-mysql - 1.10.0) Add-on from Paper-UI and get it to log all items state changes using the following ‘mysql.persist’ Persistence file:
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every5Minutes : "0 */5 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
* Each line in this section defines for which item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* item (excl. the group item itself).
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyUpdate, restoreOnStartup
The console thew some errors (and still seems to now and then) that:
21:45:56.097 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
21:45:56.116 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query '##ITEM NAME##'.
21:45:56.119 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query '##GROUP NAME##'.
... etc
BUT then I have tables like ‘Items’ that seems to contain a list of all items that have had a value change since the persistent stuff was setup and a corresponding table ‘Item1’ for example that has the time and a string representing the new value…
#Problem:
This is great (or a good start) but I can’t find any information on how to take this further and push my own messages from the rules into my own tables?
So can someone point me in the right direction… I am kind of assuming it’s possible! If this assumption is wrong I guess can someone break the bad news and maybe offer an alternative way of permanently logging what functions ran at what time and any information and data I want to dump out…
