gregd
(Greg)
October 8, 2018, 8:59pm
1
I requested a new device to be added to the ZWave database. BTW Thank you @chris !
As I’m waiting for a new buiild, I’m trying to figure out what the process is to load the new jar, I came across this post that has the steps and the location of the zwave nightly build:
https://community.openhab.org/t/how-do-i-get-an-addon-zwave-from-the-nightly-build/48132/3
The filename of the nightly build appears it is for OH 2.4.0, but I’m running the 2.3.0 Release Build.
Do I have to upgrade my OH from 2.3.0 → 2.4.0? Or can I load the 2.4.0 nightly build jar right into 2.3.0?
I know a newb question, but I wanted to ask
Greg
5iver
(Scott Rushworth)
October 8, 2018, 9:18pm
2
Others have done this successfully. But others have also reported 500 errors when configuring devices and upgrading to a snapshot fixed them. YMMV.
Also, this may be helpful. If you use it, select the Master branch, not Development.
A number of people have run into trouble performing manual installs of the Zigbee and Z-Wave bindings. A manual install (dropping the jar into addons) is rarely needed, but some people prefer a manual install over apt-get, or want to use a stable OH release with a recent Zigbee or Z-Wave binding. Here is a script that will hopefully make it easier to install, upgrade, and uninstall these bindings, and prevent some of the common issues.
Who would benefit from this script:
Anyone wanting to tes…
elite
(Nick)
October 8, 2018, 9:25pm
3
I ran the dev zwave binding on 2.3 without issue - I have now moved to the milestone builds (more up to date than release, but more tested than snapshot. I have found it more stable than my 2.3 install, but that could well be due to other factors.
All,
I promised it since a while, but it has cost us quite some efforts to get the whole process working smoothly: We are now in a position to do almost “one-click” releases of openHAB with our Jenkins release pipeline - big thanks to @pfink for setting this up!
Just as some background information: To create a distro release, 9 different Github repos need to be built and released individually, with versions being changed in the sources, git tags being created, p2 repos published, etc.
Doing t…
gregd
(Greg)
October 8, 2018, 9:51pm
4
Thank you @5iver and @elite !
@5iver I tried out your script and I loaded the zwave binding into my OH!
