Hi I am new to OpenHab.
I have the server working and have bound it to a wemo light switch. I can control the wemo from any web browser that is pointed to the computer that is running the server. Unfortunately I can not connect through the OS mobil app from my iPhone (although I can connect through the iPhone via the browser. Using the app down loaded from the store and using the same root of the http: address but still no luck. Any ideas? I get ERROR Request Failed internal server error (500)
regards
Max
Hi Max,
Please advise what local URL you have used in your seetings.
Cheers
Björn
Hi Bjorn
I use the IP address of this computer on my network i.e. http://192.168.8.102:8080
I reloaded the program and still I can not connect via the OS application. Using a web browser I do connect however then get no icons
Max
Hi
Are you using wifi (i.e. Your internal network) or the data connection on your iPhone ?
In the first case i Leave “Blank” Local URL so the app start in discover mode
In the second case i use bind myopenhab
Hi Antonio
Thanks for the suggestion, its appreciated, however still no joy.
I used the wifi i.e. without cell and no local url and still it will not connect. it is trying to discover openhab however after that I still get the same error
Internal error. Internal server error 500
I think the problem my be on my apple Macbook Pro laptop i.e. something to do with ports, firewalls or java settings. I have the same software on a mac mini and the os app connects to that. Obviously I run the two servers at different times.
any other ideas are welcome as this is driving me nuts
Max
looks like http-alt is on port 8080. what is http-alt. Now I need to find a way to with move http-alt or start openhab on another port
any ideas folks
[X]
Hi Max,
Seems to be the same issue than with your openhab app.
Change port in start.sh using Notepad++ or some other editor.
File can be found in directory OpenHab.
Cheers
Björn
Dear Bjorn
I switched off my firewall on my router yesterday and it worked. I do not want to keep the firewall permanently off so I am playing around with port forwarding. I will reply to your other question
You help is most appreciated
Max Birley
+353 87 462 7660
Skype mdbirley
Same issue here. Switching of the public firewall and the iPhone app can connect to the server. As Max already mentioned, i do not want to keep the firewall permanently open.
What kind of firewall setting/rules are needed?
