Mpower
(M)
1
- Platform information:
- Hardware: Raspberry PI2
- OS: _latest openhabian
- Issue of the topic:
I just installed openhabian with latest version and it’s running but I can’t install bining via Paper UI I see the following errors in the log:
2018-10-27 18:11:27.526 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-zwave': Error:
Error downloading mvn:org.openhab.binding/org.openhab.binding.zwave/2.3.0
Topsurfer
(Martin)
2
I get exact the same error message,
also running openhabian on Raspi.
Can anyone confirm that there is an issue with the “source”?
Any workaround, because just plug in the zwave USB stick and want to test …
Topsurfer
(Martin)
3
Update:
after 65 minutes I get:
2018-10-28 10:31:20.562 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-zwave’: Error:
2018-10-28 11:34:08.808 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-zwave’: Error:
2018-10-28 11:36:54.783 [thome.event.ExtensionEvent] - Extension ‘binding-zwave’ has been installed.
Mpower
(M)
4
Re-installed the image --> problem solved
