- Platform information:
- Hardware: _RPi4
- OS: Openhabian 1.5
Hi all,
I just downloaded the image for openhabian 1.5 from github and put everyting on a SD card. I did not change anything in openhabian.conf file. Using ethernet cable for connection to the internet. The installation always stops at:
2020-06-21_11:20:49_BST [openHABian] Updating repositories and upgrading installed packages… FAILED
2020-06-21_11:21:43_BST [openHABian] Initial setup exiting with an error!
I ssh-ed into the RPi and tried to do manually and upgrade of all packages to see what is going on. I got all these errors:
apt-listchanges: Can’t set locale; make sure $LC_* and $LANG are correct!
Reading changelogs… Done
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_TIME = “nl_NL.UTF-8”,
LC_MONETARY = “nl_NL.UTF-8”,
LC_ADDRESS = “nl_NL.UTF-8”,
LC_TELEPHONE = “nl_NL.UTF-8”,
LC_NAME = “nl_NL.UTF-8”,
LC_MEASUREMENT = “nl_NL.UTF-8”,
LC_IDENTIFICATION = “nl_NL.UTF-8”,
LC_NUMERIC = “nl_NL.UTF-8”,
LC_PAPER = “nl_NL.UTF-8”,
LANG = “en_GB.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to a fallback locale (“en_GB.UTF-8”).
debconf: Perl may be unconfigured (Unrecognized character \xFF; marked by ← HERE after ← HERE near column 1 at /usr/share/perl/5.28/FileHandle.pm line 1.
Compilation failed in require at (eval 1) line 3.
BEGIN failed–compilation aborted at (eval 1) line 3.
) – aborting
Setting up libpam0g:armhf (1.3.1-5+rpt2) …
Missing right curly or square bracket at /usr/share/perl/5.28/base.pm line 129, at end of line
syntax error at /usr/share/perl/5.28/base.pm line 129, at EOF
Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 7.
BEGIN failed–compilation aborted at /usr/share/perl5/Debconf/Log.pm line 7.
Compilation failed in require at /usr/share/perl5/Debconf/Db.pm line 7.
BEGIN failed–compilation aborted at /usr/share/perl5/Debconf/Db.pm line 7.
Compilation failed in require at /usr/share/debconf/frontend line 6.
BEGIN failed–compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing package libpam0g:armhf (–configure):
installed libpam0g:armhf package post-installation script subprocess returned error exit status 255
Errors were encountered while processing:
libpam0g:armhf
E: Sub-process /usr/bin/dpkg returned an error code (1)
Anybody any idea what is going on? I tried several times. Tried different SD cards, but nothing seems to work.
Cheers, Rico
