ROS
(Rune Olav StrandÄs)
May 15, 2021, 3:57pm
1
Hi.
I can not write a value to KNX from OH3, but I can read them.
Switches are working both ways.
This command should work:
KNXTermostatVarmekasett_VarmekasettSetpunktInn.sendCommand(temp)
I have checked the KNX bus and it does not receive anything.
What shall I do?
ROS
J-N-K
(Jan N. Klug)
May 15, 2021, 5:17pm
4
Please show your configuration
ROS
May 15, 2021, 5:31pm
6
Here is the thing:
UID: knx:device:gatway:termostat_varmekasett
label: KNX Termostat Varmekasett
thingTypeUID: knx:device
configuration:
pingInterval: 600
address: 1.0.7
readInterval: 0
fetch: false
bridgeUID: knx:ip:gatway
channels:
channelTypeUID: knx:number
label: Varmekasett Setpunkt
description: ââ
configuration:
ga: 0/1/0
label: Varmekasett Setpunkt Inn
description: ââ
configuration:
ga: 9.001:0/1/1
label: Varmekasett Temperatur
description: ââ
configuration:
ga: 0/1/2
channelTypeUID: knx:switch
label: Varmekasett Utgang 1
description: ââ
configuration:
ga: 0/1/3
label: Varmekasett Tilbakemelding 1
description: ââ
configuration:
ga: 0/1/4
label: Varmekasett FĂžlerstatus 1
description: ââ
configuration:
ga: 0/1/5
label: Varmkasett Temperatur 2
description: ââ
configuration:
ga: 0/1/12
label: Varmekasett Utgang 2
description: ââ
configuration:
ga: 0/1/13
label: Varmekasett FĂžlerstatus 2
description: ââ
configuration:
ga: 0/1/15
J-N-K
(Jan N. Klug)
May 15, 2021, 5:32pm
7
0/1/1 is the one that is not working?
ROS
May 15, 2021, 5:48pm
8
Yes.
But I have other things that also send a value and are not working.
Since it is not in the openhab log, I think the command never get executed.
J-N-K
(Jan N. Klug)
May 15, 2021, 5:51pm
9
Does it work if you use openhab:send ItemName Value on the karaf console? If that works, the problem is kn your rule. If it also doesnât work, itâs a binding issue.
ROS
May 16, 2021, 1:14pm
10
But is it not strange that ON/OFF signals go both ways and that I can read values from KNX?
I get no errors in the log, but it registered the sending in the log:
2021-05-16 15:09:04.100 [INFO ] [openhab.event.ItemCommandEvent ] - Item âKNXTermostatVarmekasett_VarmekasettSetpunktInnâ received command 23.45
2021-05-16 15:09:04.103 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item âKNXTermostatVarmekasett_VarmekasettSetpunktInnâ predicted to become 23.45
2021-05-16 15:09:04.111 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âKNXTermostatVarmekasett_VarmekasettSetpunktInnâ changed from 23.46 °C to 23.45 °C
But nothing was on the KNX bus,
I shall try to use the console, but I have never used it and the Raspberry is in a cabinet in the basement. I shall try to connect to it.
ROS
rossko57
(Rossko57)
May 16, 2021, 1:18pm
11
Is that Item linked to any channel?
ROS
May 16, 2021, 1:30pm
12
Yes it is. I have included the hole thing, scroll up
rossko57
(Rossko57)
May 16, 2021, 1:59pm
13
The hole Thing does not show any links to any Item. (Itâs not supposed to, you need to check elsewhere for that.)
ROS
May 16, 2021, 4:00pm
14
It is linked to KNXTermostatVarmekasett_VarmekasettSetpunktInn.
I use UI to configure and add equipment into the model. No manual configuring, except for the KNX channels.
I have done everything âby the bookâ
rossko57
(Rossko57)
May 16, 2021, 4:04pm
15
Which of the many "it"s? We could guess, but you have a problem you are investigating. Be sure.
Have you specified a dimension to the item? I had a similar issue where the write was ignored when I set the Temperature dimension on the item. This was on OH2 but I havenât tested on OH3 so it might be the same.
ROS
May 16, 2021, 4:55pm
17
Yes I have done that. This should not be a problem and I dont know where to look. Since there are no error in the log it is difficult.
So you removed the dimension and it still fails?
J-N-K
(Jan N. Klug)
May 16, 2021, 6:28pm
19
Looking at the code that might be your problem. There is no mapping for QuantityType, only for DecimalType and QuantityType does not extend DecimalType. Just guessing.
Edit: Confirmed. The binding does NOT support sending values with units. This fails:
@Test
public void testToDPTValueQuantityType() {
assertEquals("23.1", new KNXCoreTypeMapper().toDPTValue(new QuantityType<>("23.1 °C"), "9.001"));
Thanks Jan, shall I raise as bug/enhancement in github? ROS if you have units defined on your item then this will be you
