I feel like a noob asking this but I’ve tried with multiple different settings, different cameras, searched literally hundreds of different topics here and I could never put a camera properly working with OH.
My system is based on a RPi4 and I’m running OH3.3.
First, can someone that have a live feed working, share full settings so I can literally copy and test it that way?
Then, is it possible to eventually control the camera pan, tilt and zoom?
Last but not least, would this work remotely (not only inside the same network)?
Right now the solution I have is using a link to capture a frame and I update the link each 2 seconds, but that only works locally, not remotely and it’s not even a good solution.
I appreciate your help. Unfortunately for me, it still does nothing.
I have some cheap Hiseeu wifi IP cameras and then I have a Xiaomi IP camera and another “white lable” IP camera that I can get live image from an RTSP link if I use VLC Media Player.
For the others I use them connected to an NVR from Hiseeu and an APP, which works fine.
I used this website to check what URLs I should use and for the snapshots it works perfectly but I cannot put it working with video.
You will need to change the ffmpegInputOptions to -f mjpeg otherwise you will not be able to record and a few other features that ffmpeg give you. Most cameras are h264 based steams, so this change is needed for cameras that have mjpeg based streams.
I would not copy other peoples setups, instead just use the GUI to add a generic camera and fill in the fields that are shown without needing to tick the advanced box. Everything that is needed should be shown without going advanced and confusing you more. If the camera has a working rtsp link then it should work, if not then look at the first paragraph of the ip camera documentation on how to get DEBUG or TRACE level logs. The section is titled what to do if you have issues, and its what you should do if you need help
Sounds like that is the problem, try using google to find other possible working urls for the cameras. Sadly a lot of cameras are only designed to be used with X mobile app, so sometimes you can find some info by using ‘wireshark’ to spy on what traffic is going between the app and the camera.
