Hi everyone.
I´m trying to create my first rule which will eventually (when I get it working) will send temperature and humidity updates to Thinkgspeak.
Items:
Number office_temp "Temperatura [%.1f ºC]" <temperature> (grpOffice) {mqtt="<[mosquitto:office/sensor/temp:state:default]"} Number office_hum "Humedad [%.1f %%]" <humidity> (grpOffice) {mqtt="<[mosquitto:office/sensor/hum:state:default]"}
Rule:
import org.joda.time.*
rule "Send data to Thingspeak"
Time cron "1 0/1 * * * ?"
logInfo("Thingspeak", office_temp.state)
logInfo("Thingspeak", "Temp & Hum sent to Thingspeak")
If I uncomment this line: logInfo("Thingspeak", office_temp.state), then I get:
2016-05-04 18:36:01.072 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Send data to Thingspeak
java.lang.IllegalStateException: Could not invoke method: org.openhab.model.script.actions.LogAction.logInfo(java.lang.String,java.lang.String,java.lang.Object[]) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_101]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) ~[na:1.7.0_101]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.7.0_101]
at java.lang.reflect.Method.invoke(Method.java:606) ~[na:1.7.0_101]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
... 26 common frames omitted
What´s wrong with it?
TIA
