Can I know if we can control the swimming pool management system using the openhab2? If so ,can I know how can we do it ?Also can anyone help me out with the bindings for the same?
thanks
Nikhil
thanks
Nikhil
@nikhilteja_v - It all depends on the pool controller. What brand and model number is it?
Like can I know what are all the brands with model number available that supports KNX system and can be controlled using OPENHAB2 for pool controller?
No it doesn’t work that way.
There’s no lists of supported systems because maintaining those lists is impossible.
You have to select hardware yourself, and you have to figure out how to control it yourself using OH bindings and rules, eventually.
This also applies to your other post.
And you’ve posted to the wrong section.
Read and follow this before your next post, please:
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
