I am now successfuly running this rule for a timer latch design but my log looks terrible.
Maybe the rule isn´t correct yet?
the only rule in use (successfuly working):
var Timer shutoffTimer= null
var DateTime lastRun = now.minusMinutes(1) // on a reboot switch on sirene on the first event
rule “PIR Neo_PIR_1 for Switch with Siren”
	Item NEO_PIR_1_Bewegung changed from OFF to ON
	if(AlarmInnen.state==ON) {
		if(lastRun.isBefore(now.minusMinutes(1))) {
			if(shutoffTimer==null) {
			sendCommand(zwave_device_296beed3_node4_switch_binary, ON)
				lastRun = now
			logInfo("RuleInfo", "Siren START")
			timer = createTimer(now.plusSeconds(10)) [|
				sendCommand(zwave_device_296beed3_node4_switch_binary, OFF)
				logInfo("RuleInfo", "Siren STOP")
			timer = null
openhab.log:
2018-03-04 16:42:58.059 [INFO ] [ipse.smarthome.model.script.RuleInfo] - Siren START
2018-03-04 16:42:58.247 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘PIR Neo_PIR_1 for Switch with Siren’: An error occurred during the script execution: Couldn’t invoke ‘assignValueTo’ for feature JvmVoid:  (eProxyURI: G11.rules#|::0.2.0.2.0.0.1.0.0.1.0.0.1.0.3::0::/1)
2018-03-04 16:43:08.108 [INFO ] [ipse.smarthome.model.script.RuleInfo] - Siren STOP
2018-03-04 16:43:08.115 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.2018-03-04T16:43:08.066+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
sendCommand(,)
logInfo(,)
.timer =
} ] threw an unhandled Exception:
java.lang.IllegalArgumentException: Couldn’t invoke ‘assignValueTo’ for feature JvmVoid:  (eProxyURI: G11.rules#|::0.2.0.2.0.0.1.0.0.1.0.0.1.0.3.7.6.1.1.0.2::0::/1)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1224) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1212) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:215) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy153.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
2018-03-04 16:43:08.149 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.2018-03-04T16:43:08.066+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
sendCommand(,)
logInfo(,)
.timer =
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
Caused by: java.lang.IllegalArgumentException: Couldn’t invoke ‘assignValueTo’ for feature JvmVoid:  (eProxyURI: G11.rules#|::0.2.0.2.0.0.1.0.0.1.0.0.1.0.3.7.6.1.1.0.2::0::/1)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1224) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1212) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy153.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
… 1 more
