- Platform information:
- Hardware: Raspberry Pi 3 B+
- OS: openhabian
- openHAB version: 3.4
- Issue of the topic:
Hello all,
I have the Multisensor 7 from Aeotec connected with USB cable. In the configuration, however, Power Status is 0 (which means battery mode) and the value is readonly. With the support of Aeotec I have now written longer back and forth and now came this:
I did some tests and it should switch to battery or USB power accordingly in this case.
Parameter 10 = 1 = USB power
Parameter 10 = 0 = battery power
This is reflected well when I use the Home Assistant with ZWaveJS UI, this only seems to change when I send a "Configuration GET" command to parameter 10, which is then updated.
Are you able to do a Configuration Get on parameter 10 to update the parameter state?
Is it possible to execute a “Configuration GET” in OH? Because I don’t want to switch to Home Assistant.
Best regards
