Platform information:
Hardware: Intel i7 with 4gb ram
OS: Ubuntu 18.04 Server LTS
Java Runtime Environment:
root@daqsrv7:~# java -version
openjdk version “1.8.0_265”
OpenJDK Runtime Environment (Zulu 8.48.0.53-CA-linux64) (build 1.8.0_265-b11)
OpenJDK 64-Bit Server VM (Zulu 8.48.0.53-CA-linux64) (build 25.265-b11, mixed mode) -
openHAB version:
root@daqsrv7:~# dpkg -l | grep openhab2
ii openhab2 2.5.8-1 all openhab2
ii openhab2-addons 2.5.8-1 all openhab2-addons
Issue of the topic: Cannot access local web page
Please post configurations (if applicable):
- Default items
- Default Sitemap
- Default Rules
- Default Services configuration
I change the ports and ip address in config file to 9090, 9443 and 192.168.1.207 which is the address of the computer. I have other things running on 8080 etc.
- If logs where generated please post these here using code fences:
2020-09-19 15:35:36.446 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2020-09-19 15:35:37.589 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:989) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:468) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:487) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:1004) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.util.tracker.BaseActivator.register(BaseActivator.java:425) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.register(BaseActivator.java:413) ~[bundleFile:?]
at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:180) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:312) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_265]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
2020-09-19 15:35:57.076 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2020-09-19 15:35:58.206 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
2020-09-19 15:36:15.996 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2020-09-19 15:36:17.134 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
This was a clean install using the APT install guide directly from the Openhab website. Prior to this current error i had a “address in use” error when checking the logs i saw permission denied on the the /var/log/openhab folder can anyone tell me the proper permissions for those files, i changed them to openhab for owner and added +x permissions which brought me to this current error.
I cannot use the pre built image this is and existing lamp server with many other things already running on it.
