- Platform information:
- Hardware: Openhabian on 4GB Pi 4
- OS: Openhabian
- Java Runtime Environment:
- openHAB version: 2.5
- Issue of the topic: I cannot get the astro binding to use the correct location. It always shows a location in Germany and sets the sunrise/sunset, etc based on that.
Astro is installed from addons.cfg.
Astro.cfg file:
# The latitude
latitude=33.0429792
# The longitude
longitude=-97.1467081
# Refresh interval for azimuth and elevation calculation in seconds
# (optional, defaults to disabled)
#interval=
astro.things file:
astro:sun:home [ geolocation="33.0407936,-97.1423744", interval=60 ]
astro:moon:home [ geolocation="33.0407936,-97.1423744", interval=60 ]
The system location is set and shows up correctly. I have cleared the cache multiple times (openhab-cli clean-cache) and it makes no difference. When I try to change the location in Astro using the paper UI I get a 409 conflict error. I also looked at the config file in /openhab2-userdata/config/org/astro.config. It is set there correctly also.
Any suggestions?
