Hi all,
after upgrading my openhabian installation vom 3.4.1 to 4.1.0 first everything looks fine, but the connection to InfluxDB-Cloud does not work anymore. I didn’t change any settings. Found something in openhab.log that looks strange and could be an hint for the cause for the error:
2023-12-25 15:34:15.345 [WARN ] [rnal.influx2.InfluxDB2RepositoryImpl] - database not ready
2023-12-25 15:34:15.348 [INFO ] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service started.
2023-12-25 15:34:15.350 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : invoking bind: setItemFactory: parameters [org.openhab.core.library.CoreItemFactory]
2023-12-25 15:34:15.358 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : invoked bind: setItemFactory
2023-12-25 15:34:15.359 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : getting activate: activate
2023-12-25 15:34:15.361 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : Locating method activate in class org.openhab.persistence.influxdb.InfluxDBPersistenceService
2023-12-25 15:34:15.363 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : Declared Method org.openhab.persistence.influxdb.InfluxDBPersistenceService.activate([interface org.osgi.service.component.ComponentContext]) not found
2023-12-25 15:34:15.364 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : Locating method activate in class java.lang.Object
2023-12-25 15:34:15.366 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
2023-12-25 15:34:15.367 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : activate method [activate] not found, ignoring
2023-12-25 15:34:15.368 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : Set implementation object for component
2023-12-25 15:34:15.370 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:4.1.0 (278)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(401)] : Changed state from satisfied to active
2023-12-25 15:34:15.541 [DEBUG] [.influxdb.InfluxDBPersistenceService] - Connection lost, trying re-connection
2023-12-25 15:34:16.119 [WARN ] [b.client.internal.InfluxDBClientImpl] - The exception occurs during check instance readiness
Did this happen to anyone else of you? Or something similar? Would be very happy for some help.
Thanks and best regards,
Marc
