Hi there,
I’m trying to connect to raspberrymatic through the homematic bridge.
When try to connect, I get:
COMMUNICATION_ERROR
org.xml.sax.SAXException: Unknown XML-RPC tag: title
My bridge config is:
UID: homematic:bridge:af15b48c08
label: Homematic Bridge
thingTypeUID: homematic:bridge
configuration:
cuxdPort: 8701
socketMaxAlive: 900
installModeDuration: 60
userName: Admin
callbackRegTimeout: 120
hmIpPort: 2010
timeout: 15
factoryResetOnDeletion: false
discoveryTimeToLive: -1
password: xxx
wiredPort: 2000
gatewayType: auto
callbackHost: 192.168.1.61
useAuthentication: true
groupPort: 9292
gatewayAddress: 192.168.1.2
unpairOnDeletion: false
rfPort: 2001
bufferSize: 2048
channels:
- id: DUTY_CYCLE_RATIO
channelTypeUID: homematic:DUTY_CYCLE_RATIO
label: Duty Cycle
description: Current duty cycle usage
configuration: {}
I’m starting raspberrymatic in docker with:
docker run -d \
--name ccu \
--privileged \
-v ccu_data:/usr/local:rw \
-p 2001:2001 \
-p 2010:2010 \
-p 9292:9292 \
ghcr.io/jens-maus/raspberrymatic:latest
raspberrymatic itself works, I’m using an HmIP-RFUSB with some configured devices.
The network seems to be okay as well.
I’m unsure how to debug this or what the exact problem might be - can anyone maybe help?
