Cannot convert from State to HSBType
I have the follwing rule which gives me an error in the LSP (VSCode):
rule “WLED: Adapt Color Parameter to WLED Notation”
Item WLED_Color received update
val HSBType newLEDState = triggeringItem.state
val rgb = 16777215 + newLEDState.getRGB
val mqttActions = getActions(“mqtt”,“mqtt:broker:mosquitto”)
mqttActions.publishMQTT(“wled/wztv/col”,"" + rgb)
Error message: Type mismatch: cannot convert from State to HSBType
My item definition is like this:
Color WLED_Color “Farbe” (Group_WLED)
Any ideas what causes the message and how I could prevent it from showing up?
Thanks,
Boby
It means what it says. An openHAB state object (which may have states like ON, CLOSED or 50% etc.) is not directly parsable by the HSB constructor.
You should be able to cast the state to HSBType
val newLEDState = triggeringItem.state as HSBType
Do you want to try a binding for WLED
Download and unzip into your openhab2-addons directory.
Its best to set a static ip on the WLED for this to work
