Platform information:
- Hardware: RPi 3
- OS: _Openhabian 2
- Java Runtime Environment: _openhabian build
- openHAB version: 2
Issue of the topic:
I’m trying to add 2 items to show if they are present on the network. I’m using the Network Binding.
But the values I see on the console are all wrong. It shows devices are on the network when they are not, I cannot get the ping times to show, neither the “last seen” values. I’ve tried “number” and “string” in my config but it makes no difference.
Here is my config:
In sitemap, I just refer to the group
Group item=grp_devices label=“Network Devices” icon=“esp8266” (I made my own icon)
In items
Switch Thing1 “Thing1” (grp_devices) { channel=“network:pingdevice:Thing1:online” }
Number Thing1ResponseTime “Ping time” (grp_devices) { channel=“network:pingdevice:Thing1:latency” }
// DateTime 1LastSeen (grp_devices) { channel=“network:pingdevice:Thing1:lastseen” } (commented for troubleshooting)
String Thing2 “Thing2” (grp_devices) { channel=“network:pingdevice:Thing2:online” }
String Thing2ResponseTime “Ping time”(grp_devices) { channel=“network:pingdevice:Thing2:latency” }
// DateTime 2LastSeen (grp_devices) { channel=“network:pingdevice:Thing2:lastseen” } (commented for troubleshooting)
Things:
network:pingdevice:Thing1 [ hostname=“192.168.0.19”, timeout=2000, refreshInterval=10000 ]
network:pingdevice:Thing2 [ hostname=“192.168.0.20”, timeout=2000, refreshInterval=10000 ]
This is the log output.
2017-11-13 19:43:19.433 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘115.482537’ for item ‘Thing2ResponseTime’ to handler for channel ‘network:pingdevice:Thing2:latency’, because no thing with the UID ‘network:pingdevice:Thing2’ could be found.
2017-11-13 19:43:29.314 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘ON’ for item ‘Thing2’ to handler for channel ‘network:pingdevice:Thing2:online’, because no thing with the UID ‘network:pingdevice:Thing2’ could be found.
2017-11-13 19:43:29.320 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘5.238609’ for item ‘Thing2ResponseTime’ to handler for channel ‘network:pingdevice:Thing2:latency’, because no thing with the UID ‘network:pingdevice:Thing2’ could be found.
I’ve tried so many options, I’m driving myself crazy. I’ve tried also to config via PaperUI, without any success.
I also would like to see if two iPhones are on the network, but that is later, for now I want to ping two ESP8266 relays to see if they go down.
Any suggestions would be greatly appreciated.
(i’m not 100% sure which version I’m running but I downloaded the image a few weeks ago)
Thanks in advance
