I am trying to install open habian on a pi 3 b+ and I am just not getting anything. I have done a raspian and manually installed everything. I have no issue getting the pi to work. openhabain I give the 45mins but nothing.
I have tried a different cable, hub, SD card used mac & pc with etcher and also other means in windows to write the image also different power supplies all work well with the raspian but not the habian.
Interestingly the LAN never initiates either, any suggestions as to what I am ding wrong.
openHABian needs to be updated to contain the latest version of the rpi firmware I think. You can install Raspbian lite and then apply openHABian manually.
Hi
I have this same issue with Raspberry 3 B+. When I try install openhabian 1.4, I have only rainbow on the monitor and green LED is flashing 4 times. When I was try install openhabian 1.3 the red LED is flashing 4 times, and nothing happens.
This same when I’m trying install PIHole, etc. Only RASPBIAN STRETCH WITH DESKTOP Working Correctly. On the Raspbian Lite can’t connect SSH.
This same SD card (Sandisk Ultra 16gb) with Openhabian 1.4 start booting with out any problems on Raspberry 3.
What can be wrong with 3B+??
Any ideas ??
I’m having similar issues. New user of the Raspberry pi 3 model b plus. Stuck on black screen when trying to install openhabian. I have no keyboard so I tried the automatic method using etcher on a Mac and a 32 gig Samsung Evo SD card. 4th attempt and still stuck on black screen after 6 hours. On the previous attempt I disconnected it after 10 hours and i could not login to the GUI but the network share showed up on my Mac.
When you say Stuck on black screen, is that after watching it install on the monitor, then it goes to a black screen? If so, thats normal, openhabian runs headless. Have you tried to connect via ssh? On the GUI you may need to try Your local IP address like http://10.0.1.20:8080/start/index. If you can see it showing on network share I would think it’s working.
