Cannot invoke method public abstract float java.lang.Number.floatValue() on null
  • Platform information:
    • openHAB version: 5.2.3
I have the follow rule:
rule "Wasserverbrauch Tag Woche Monat Jahr"
    Item rawwater changed
    val ZonedDateTime zdt            = ZonedDateTime.now()                                              // jetzt
    val ZonedDateTime start_of_day   = zdt.with(LocalTime.MIDNIGHT)                                     // heute, Mitternacht
    val ZonedDateTime start_of_week  = start_of_day.minusDays(start_of_day.getDayOfWeek.getValue - 1)   // Montag
    val ZonedDateTime start_of_month = start_of_day.withDayOfMonth(1)                                   // Erster Tag des Monats
    val ZonedDateTime start_of_year  = start_of_day.withDayOfYear(1)                                    // Erster Tag des Jahres
    if ((rawwater.deltaSince(start_of_day)   as Number).floatValue != null)
        val rawwater_Heute = (rawwater.deltaSince(start_of_day)   as Number).floatValue
        rawwaterTag.postUpdate(rawwater_Heute)
    if ((rawwater.deltaSince(start_of_week)  as Number).floatValue != null)
        val rawwater_Woche = (rawwater.deltaSince(start_of_week)  as Number).floatValue
        rawwaterWoche.postUpdate(rawwater_Woche)
    if ((rawwater.deltaSince(start_of_month) as Number).floatValue != null)
        val rawwater_Monat = (rawwater.deltaSince(start_of_month) as Number).floatValue
        rawwaterMonat.postUpdate(rawwater_Monat)
    if ((rawwater.deltaSince(start_of_year)  as Number).floatValue != null)
        val rawwater_Jahr  = (rawwater.deltaSince(start_of_year)  as Number).floatValue
        rawwaterJahr.postUpdate(rawwater_Jahr)
Shortly after the start of each new day, I get the following error:
Script execution of rule with UID ‘judo-4’ failed: cannot invoke method public abstract float java.lang.Number.floatValue() on null in judo
What’s the problem here?
This problem doesn’t occur the rest of the day—only shortly after midnight.
Shortly after start of the day is the delta null.. No data.. I have something similar with daily kwh
The problem is the order in your check. deltaSince returns null shortly after midnight, because no persisted value exists yet for the new day. Your if condition already calls .floatValue on that null, so the error is thrown before the check can do anything. Check the result for null first, then cast:
    val dTag   = rawwater.deltaSince(start_of_day)
    val dWoche = rawwater.deltaSince(start_of_week)
    val dMonat = rawwater.deltaSince(start_of_month)
    val dJahr  = rawwater.deltaSince(start_of_year)
    if (dTag !== null)   rawwaterTag.postUpdate((dTag as Number).floatValue)
    if (dWoche !== null) rawwaterWoche.postUpdate((dWoche as Number).floatValue)
    if (dMonat !== null) rawwaterMonat.postUpdate((dMonat as Number).floatValue)
    if (dJahr !== null)  rawwaterJahr.postUpdate((dJahr as Number).floatValue)
Note: until the first value of the new day is persisted, the daily item keeps showing the previous day’s value. If you prefer 0 in that window, add an else rawwaterTag.postUpdate(0) branch.
The same null window can also affect the week, month and year deltas at their boundaries, not just the daily one, so it is worth applying the same null check to all four values rather than only the one that happened to fail first. Storing each delta in its own variable first and checking it before calling floatValue keeps the rule readable and avoids repeating the persistence call. If you want the daily item to read 0 instead of holding yesterday’s value until the first new reading arrives, an else branch posting 0 is a clean way to handle that gap.
Now I realize why the error has only occurred sporadically. I’ll keep an eye on this for a while.
Thanks!
