Cannot refer to the non-final variable i inside a lambda expression
Hi All,
I’m trying to read a variable from inside a loop (Lambda) but getting an error about “non-final variable”. I understand why i’m getting this error but I don’t know how to break up my rule so I can read the variable.
Can any one assist?
Glenn
rule "Test"
		Item Testa received update
		if (Testa.state == ON){
			var i = 1
    		while((i=i+1) < 360) {
    			GF_Hall?.allMembers.forEach(item|
					if( item.name.toString.startsWith("Light_") && item instanceof ColorItem){
				   		item.sendCommand(i + ",100,100")
	        	Thread::sleep(500)
	        	if (Testa.state == OFF){
	        		i=360
The workaround is to define i as a global variable.
Actually you can just ignore that error; it’s just Designer acting naughty. I have several rules that run fine even though Designer complains.
Both answers 100% worked.
Thanks for the help!
Thanks :smile:
