I just upgraded from OH 4.2.2 to 4.3.5 and wanted to get rid if a manually added binding, because the binding is now officially part of OH.
I removed the file from the addon-folder and restarted the docker container of OH. The binding still showed up.
Then I deleted the container and recreated it, hoping cached stuff will be cleaned up then.
But the binding still shows up in the UI as installed.
When I click “remove” in the UI, it fails and I get this log entry:
2025-06-17 10:43:59.534 [ERROR] [t.core.internal.addons.AddonResource] - Exception while uninstalling add-on: null
What else can I do?
edit:
Tried via karaf, but also cannot get rif of the .jar binding
