I realy need help. I configured my server on Windows and everything was working fine, now i thought i cant just port it to Linux. I used an apt install, installed all the stuff i need now i can only access the first page off my sitemap and only over localhost.
please help me do get this solved.
I have the following log files (deleted IPS / Device IDS)
2015-12-11 15:24:41.396 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.1).
2015-12-11 15:24:50.605 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2015-12-11 15:24:50.778 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2015-12-11 15:24:56.509 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist'
2015-12-11 15:24:57.925 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'Wohnung.items'
2015-12-11 15:25:10.225 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'Wohnung.sitemap'
2015-12-11 15:25:19.683 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2015-12-11 15:25:25.735 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
2015-12-11 15:25:32.747 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'Wohnung.rules'
2015-12-11 15:25:36.538 [INFO ] [.service.AbstractActiveService] - Netatmo Refresh Service has been started
2015-12-11 15:25:37.817 [INFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=--.4618735,longitude=--.0777284,interval=disabled,systemTimezone=Etc/UTC (UTC +0000),daylightSavings=false]
2015-12-11 15:25:40.989 [INFO ] [.b.a.internal.job.JobScheduler] - Scheduled a daily job at midnight for astro calculation
2015-12-11 15:25:43.056 [ERROR] [.myopenhab.internal.MyOHClient] - Socket.IO error: not authorized
2015-12-11 15:25:43.331 [INFO ] [.h.internal.hardware.HueBridge] - Hue bridge not paired.
2015-12-11 15:25:43.339 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 100 seconds...
2015-12-11 15:25:43.619 [INFO ] [.o.b.m.internal.MaxCubeBinding] - Discovered MAX!Cube lan gateway at '---.---.--.--'
2015-12-11 15:25:43.629 [INFO ] [.service.AbstractActiveService] - MAX!Cube Refresh Service has been started
2015-12-11 15:25:44.229 [INFO ] [.service.AbstractActiveService] - Plex Refresh Service has been started
2015-12-11 15:25:44.380 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 99 seconds...
2015-12-11 15:25:44.442 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.450 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.455 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.460 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.464 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.468 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.473 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.477 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-12-11 15:25:44.697 [INFO ] [.b.plex.internal.PlexConnector] - Plex websocket connected to ---.---.--.--:-----
2015-12-11 15:25:45.413 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 98 seconds...
2015-12-11 15:25:46.250 [INFO ] [.o.b.n.internal.NetatmoBinding] - The following Netatmo measurements are not yet configured:
--:--:--:--:--:--#Temperature (Innen)
--:--:--:--:--:--#Noise (Innen)
--:--:--:--:--:--#CO2 (Innen)
--:--:--:--:--:--#Humidity (Innen)
--:--:--:--:--:--#Pressure (Innen)
--:--:--:--:--:--#02:00:00:04:d3:5a#Temperature (Module)
--:--:--:--:--:--#02:00:00:04:d3:5a#Humidity (Module)
2015-12-11 15:25:46.439 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 97 seconds...
2015-12-11 15:25:47.505 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 96 seconds...
2015-12-11 15:25:48.558 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 95 seconds...
2015-12-11 15:25:49.611 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 94 seconds...
2015-12-11 15:25:50.650 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 93 seconds...
2015-12-11 15:25:51.678 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 92 seconds...
2015-12-11 15:25:52.736 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 91 seconds...
2015-12-11 15:25:53.796 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 90 seconds...
2015-12-11 15:25:54.856 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 89 seconds...
2015-12-11 15:25:55.896 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 88 seconds...
2015-12-11 15:25:56.954 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 87 seconds...
2015-12-11 15:25:58.012 [INFO ] [.h.internal.hardware.HueBridge] - Please press the connect button on the Hue bridge. Waiting for pairing for 86 seconds...
2015-12-11 15:25:58.087 [INFO ] [.h.internal.hardware.HueBridge] - Hue bridge successfully paired!
2015-12-11 15:26:29.986 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gFF for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:29.992 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gFF for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:29.996 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gFF for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.000 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gCZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.006 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gCZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.008 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gCZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.012 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gSZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.017 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gSZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.021 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gSZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.025 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Outdoor for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.032 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Outdoor for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.036 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Outdoor for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.040 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Status for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.045 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Status for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.048 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Status for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:30.057 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:30.074 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:30.082 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:30.086 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:30.093 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:30.100 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:30.105 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:30.109 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gFF_Living_Ceiling1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.527 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:36.536 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:36.546 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:36.551 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants2 for widget org.openhab.model.sitemap.Colorpicker
2015-12-11 15:26:36.557 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.564 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.570 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.577 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Plants1 for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.584 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Right for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.591 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Right for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.597 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Right for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.602 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Right for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.609 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Left for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.616 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Left for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.622 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Left for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.626 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Left for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.632 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Ceiling for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.638 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Ceiling for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.644 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Ceiling for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.648 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Light_gCZ_Bed_Ceiling for widget org.openhab.model.sitemap.Slider
2015-12-11 15:26:36.655 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item PlexTVStatus_Ipad for widget org.openhab.model.sitemap.Text
2015-12-11 15:26:36.661 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item PlexTVStatus_Ipad for widget org.openhab.model.sitemap.Text
2015-12-11 15:26:36.665 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item PlexTVStatus_Ipad for widget org.openhab.model.sitemap.Text
2015-12-11 15:26:36.671 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item PlexTVStatus_ClemensTV for widget org.openhab.model.sitemap.Text
2015-12-11 15:26:36.678 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item PlexTVStatus_ClemensTV for widget org.openhab.model.sitemap.Text
2015-12-11 15:26:36.682 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item PlexTVStatus_ClemensTV for widget org.openhab.model.sitemap.Text
2015-12-11 15:26:36.686 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gCZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:36.691 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gCZ for widget org.openhab.model.sitemap.Group
2015-12-11 15:26:36.694 [ERROR] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item gCZ for widget org.openhab.model.sitemap.Group
