i downloaded the https://github.com/openhab/openhab1-addons repo
when i try to build one of the binding (serial) using “mvn clean package” i get following error:
ERROR in C:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\src\main\java\org\openhab\binding\serial\internal\SerialDevice.java (at line 257)
[ERROR] serialPort = portId.open(“openHAB”, 2000);
Can anyone help me with this?
Full mvn output:
Picked up JAVA_TOOL_OPTIONS: -Dfile.encoding=UTF-8
[INFO] Scanning for projects…
[INFO] Computing target platform for MavenProject: org.openhab.binding:org.openhab.binding.serial:1.14.0-SNAPSHOT @ c:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\pom.xml
[INFO] Fetching p2.index from https://openhab.jfrog.io/openhab/eclipse-smarthome-stable/ (172B)
[INFO] Adding repository https://openhab.jfrog.io/openhab/eclipse-smarthome-stable
[INFO] Adding repository https://dl.bintray.com/openhab/p2/openhab-core/2.0.0
[INFO] Adding repository https://dl.bintray.com/openhab/p2/openhab-deps-repo/1.0.12
[INFO] Resolving dependencies of MavenProject: org.openhab.binding:org.openhab.binding.serial:1.14.0-SNAPSHOT @ c:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\pom.xml
[WARNING] The following locally built units have been used to resolve project dependencies:
[WARNING] org.openhab.core1/1.14.0.201907050607
[INFO] Resolving class path of MavenProject: org.openhab.binding:org.openhab.binding.serial:1.14.0-SNAPSHOT @ c:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\pom.xml
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building openHAB Serial Binding 1.14.0-SNAPSHOT
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ org.openhab.binding.serial —
[INFO] Deleting c:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\target
[INFO]
[INFO] — tycho-packaging-plugin:1.0.0:build-qualifier (default-build-qualifier) @ org.openhab.binding.serial —
[INFO] The project’s OSGi version is 1.14.0.201908070449
[INFO]
[INFO] — tycho-packaging-plugin:1.0.0:validate-id (default-validate-id) @ org.openhab.binding.serial —
[INFO]
[INFO] — tycho-packaging-plugin:1.0.0:validate-version (default-validate-version) @ org.openhab.binding.serial —
[INFO]
[INFO] — maven-resources-plugin:2.4.3:resources (default-resources) @ org.openhab.binding.serial —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory c:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\src\main\resources
[INFO]
[INFO] — tycho-compiler-plugin:1.0.0:compile (default-compile) @ org.openhab.binding.serial —
[WARNING] The effective compiler target level 1.8 is incompatible with the following OSGi execution environments: [JavaSE-1.7 (assumes 1.7)] @ MavenProject: org.openhab.binding:org.openhab.binding.serial:1.14.0-SNAPSHOT @ c:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\pom.xml
[INFO] Using Groovy-Eclipse compiler to compile both Java and Groovy files
[INFO] BUILD FAILURE
[INFO] Total time: 28.585 s
[INFO] Finished at: 2019-08-07T06:49:36+02:00
[INFO] Final Memory: 25M/309M
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:1.0.0:compile (default-compile) on project org.openhab.binding.serial: Compilation failure: Compilation failure:
[ERROR] C:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\src\main\java\org\openhab\binding\serial\internal\SerialDevice.java:[257,-1]
[ERROR] 1. ERROR in C:\Projects\OpenHab\openhab-master\git\openhab1-addons\bundles\binding\org.openhab.binding.serial\src\main\java\org\openhab\binding\serial\internal\SerialDevice.java (at line 257)
[ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[ERROR] Type mismatch: cannot convert from CommPort to SerialPort
[ERROR] ----------
[ERROR] 1 problem (1 error)
[ERROR]
[ERROR] Found 1 error and 0 warnings.
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
