The following settings don’t work (error 401), why?
“openhab.connection.basicAuth.password”: “”
“openhab.connection.basicAuth.username”: “username”,
“openhab.connection.host”: “IP-address”,
“openhab.connection.port”: 8080,
“openhab.connection.authToken”: “token”
Port shall be optional but if i leave it away I get the error “deprecated config => openhab.port”. Where does it get this from? Btw, same if I leave the empty password property away.
If I asign the token to the username I get a connection but the hint to consinder to use openhab.connection.authToken" for the token. Makes sence but doesn’t work, why?
