Hey,
first of all sorry for my bad english.
I am using a Raspberry Pi 3B and already installed Openhabian 3.3 the 32 Bit Version. The Pi is connected via LAN.
I followed the Instructions but cant connect to the openhabianpi:8080 and also I tried to connect via PuTTY.
The IP I typed in was the right one from “ifconfig” and the Message that came up was “Network error: Connection Refused.”
Also I tried to ping both Devices (Pi and PC) from each other and this worked.
You would help me a lot, if someone could solve this problem.
at java.base/java.util.zip.ZipFile$Source.(ZipFile.java:1308)
at java.base/java.util.zip.ZipFile$Source.get(ZipFile.java:1271)
at java.base/java.util.zip.ZipFile$CleanableResource.(ZipFile.java:733)
at java.base/java.util.zip.ZipFile$CleanableResource.get(ZipFile.java:850)
at java.base/java.util.zip.ZipFile.(ZipFile.java:248)
at java.base/java.util.zip.ZipFile.(ZipFile.java:177)
at java.base/java.util.zip.ZipFile.(ZipFile.java:191)
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:342)
… 8 more
