openHAB2: I am able to create controls for switching a wemo mini socket and for monitoring the online state of this same device by installing the network and wemo bindings and using discovery and automatic item generation in paperUI.
Now, I am trying to do the same thing using manually edited files and have not been able to do so.
I am starting with the most simple case I can imagine:
I have a single line in a file named firstpass.things:
this line is copied from the bottom of the webpage describing the network bindings.
When I open paperUI I expected to see a network Thing listed under configuration but there is nothing there. The device IP, as well as all the other device IP’s on my network appear as expected in my inbox. Why isn’t this Thing already defined from the .things file?
Also, what is the syntax for commenting out a line in .things? Can it be used in the middle of a line to comment out the rest of the line or only at the beginning?
2 things are listed in the paperUI configuration:
one is named “network device” and has a specification “network:device:devicename”.
The 2nd is named "network device (192.168.0.104) and has a specification "network:device:192_168_0_104.
When I click on “control” only the 2nd device appears, along with its associated Items.
How do I get rid of the 1st Thing?
how do I configure the bindings using paperUI? (I assume this is documented online someplace but I couldn’t find it)
What about comments in the .things file?
