Hi.
We just noticed that we can’t change the state of any items at all from the iOS app. It works fine starting the app and getting the sitemap with the list of all devices in our house, but trying to change any of them does nothing at all. Tried from two different iOS devices with the same result. I get nothing at all in the server log when trying. It’s a bit unclear when it last worked, but at least it worked “some months ago”. Anyone knows what’s going on?
Everything works fine from Android app and from basic ui.
The server is running OH 2.5.0. The devices are running iOS 12.4.5 and OH app 2.3.1. I’ve tried connecting both using https through Apache proxy (which I normally do) and directly to the OH server.
Possibly, a problem. You can try the latest beta I put the link in a prior post.
I would suggest filing an issue on GitHub if you feel the app has a potential issue. It could be that you are the only one who has tried https.
I would like to set this up but I have to figure out how to get certs generated and such. Still on my to do list…
