Hi there,
I’ve got a problem with my python temperaturescript.
I wrote a python script to read out the temperature with a dht22 sensor.
Manually I can sucessfully read out the temperatur, but if I try to execute the python script in openhab2, it show this error report in the Paper UI:
Traceback (most recent call last): File “/home/pi/Temperaturscripte/TemperaturPi.py”, line 8, in humidity, temperature = Adafruit_DHT.read_retry(sensor, pin) File “/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.2-py2.7-linux-armv7l.egg/Adafruit_DHT/common.py”, line 94, in read_retry humidity, temperature = read(sensor, pin, platform) File “/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.2-py2.7-linux-armv7l.egg/Adafruit_DHT/common.py”, line 81, in read return platform.read(sensor, pin) File “/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.2-py2.7-linux-armv7l.egg/Adafruit_DHT/Raspberry_Pi_2.py”, line 34, in read raise RuntimeError(‘Error accessing GPIO.’) RuntimeError: Error accessing GPIO. Traceback (most recent call last): File “/home/pi/Temperaturscripte/TemperaturPi.py”, line 8, in humidity, temperature = Adafruit_DHT.read_retry(sensor, pin) File “/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.2-py2.7-linux-armv7l.egg/Adafruit_DHT/common.py”, line 94, in read_retry humidity, temperature = read(sensor, pin, platform) File “/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.2-py2.7-linux-armv7l.egg/Adafruit_DHT/common.py”, line 81, in read return platform.read(sensor, pin) File “/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.2-py2.7-linux-armv7l.egg/Adafruit_DHT/Raspberry_Pi_2.py”, line 34, in read raise RuntimeError(‘Error accessing GPIO.’) RuntimeError: Error accessing GPIO.
My .things file looks like this:
Thing exec:command:Pi_temperature "Pi Temperatur" [command="python2 /home/pi/Temperaturscripte/TemperaturPi.py", interval=5, timeout=15, autorun=true]
Does anybody know how I make a python script successfully run in openhab2?
Thanks!
Best regards
Dominik
