Can't figure my binding 'No thing types can be added with this binding'
I have started working on a binding to integrate with the AirTouch air-conditioning controller.
At the moment I have two problems.
  1. I can’t manually configure my binding.
    On the things page when I add my Thing, it says…
Add Manually
No thing types can be added with this binding.
  1. I have implemented Discovery, and my code finds the airtouch and calls thingDiscovered(discoveryResult);
    However, my AirTouch4Handler#initialize() is never called.
It feels like I am missing something simple.
Do I need to register a DiscoveryListener and then call configurationUpdated on my handler somehow?
You need to implement ThingTypeProvider or rely on XML declaration, like this: connectorio-addons/bundles/org.connectorio.addons.binding.askoheat/src/main/resources/OH-INF/thing/thing-types.xml at db6837d92e772eb81f45bcc99b9c74f32a6d7b13 · ConnectorIO/connectorio-addons · GitHub
(linking external 3.0.x addon so it is easier to navigate)
Discovery is another part of framework. It leads to detection of things which needs to be defined/declared separately. If you look back at your discovery code you for sure have there “ThingTypeUID”. This stands for <binding-id>:<thing-type-id> from above XML sample. Note - pay attention to bindingId attribute which needs to be in sync with other places in your code.
Best,
Łukasz
Thank you @splatch for your reply.
I have found that I can use AIRTOUCH4_CONTROLLER_THING_TYPE.getAsString() when building the ThingUID. That is safer, and has the prefix already prepended.
Thanks for the tip on that.
For the xml configuration for thing-types.xml it was there, but I had renamed the binding from airtouch4 to airtouch, and neglected to update the line at the top of thing-types.xml as follows…
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="airtouch4"
changing that to
<thing:thing-descriptions bindingId="airtouch"
has let me manually create it.
Additionally, discovery is now working. It find the device and adds it to the inbox.
Thanks again for your quick reply.
