maybe this is a stupid question, but i cant find the tradfri addon in my list (paper-ui -> addons). It just isnt there. Do i need to follow some other install-procedure?
Which version of Openhab do you use?
2.0.0 - do i need to upgrade?
edit: and if i have to: is the described method (deleting alot files manually and unzipping over installation without overwriting anything) still valid?
Does that mean “yes, you have to upgrade for tradfri and the description is up-to-date”?
I think yes … if I remember korrekt , than the Binding is still avaibale since 2.1.0!
The Upgrade is describe in the Link.
Thanks, upgrade worked flawlessly!
