I have spent a week at this point trying to get a switch item in OpenHab to turn on an LED in a MySensor.
Overview
MySensors 1.5.4
OpenHab 1.8 running on RPi (Jessie)
MQTTGateway (MQTT broker/server)
Success
Gateway instantiates
MySensor registers to MQTT Gateway
OpenHab registers to MQTT Gateway
SketchName is posted to OpenHab
SketchVersion is posted to OpenHab
Message data is posted to OpenHab
OpenHab post response
Failure
MySensor incomingMessage never fires
Gateway Sketch
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* REVISION HISTORY
* Version 1.0 - Created by Daniel Wiegert <daniel.wiegert@gmail.com>
* DESCRIPTION
* MyMQTT Broker Gateway 0.1b
* Latest instructions found here:
* http://www.mysensors.org/build/mqtt_gateway
* http://www.mysensors.org/build/ethernet_gateway
* Change below; TCP_IP, TCP_PORT, TCP_MAC
* This will listen on your selected TCP_IP:TCP_PORT below, Please change TCP_MAC your liking also.
* 1 -> NOTE: Keep first byte at x2, x6, xA or xE (replace x with any hex value) for using Local Ranges.
* 2 You can use standard pin set-up as MySensors recommends or if you own a IBOARD you may change
* the radio-pins below if you hardware mod your iBoard. see [URL BELOW] for more details.
* http://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/5
* Don't forget to look at the definitions in MyMQTT.h!
* define TCPDUMP and connect serial interface if you have problems, please write on
* http://forum.mysensors.org/ and explain your problem, include serial output. Don't forget to
* turn on DEBUG in libraries\MySensors\MyConfig.h also.
* MQTT_FIRST_SENSORID is for 'DHCP' server in MyMQTT. You may limit the ID's with FIRST and LAST definition.
* If you want your manually configured below 20 set MQTT_FIRST_SENSORID to 20.
* To disable: set MQTT_FIRST_SENSORID to 255.
* MQTT_BROKER_PREFIX is the leading prefix for your nodes. This can be only one char if like.
* MQTT_SEND_SUBSCRIPTION is if you want the MyMQTT to send a empty payload message to your nodes.
* This can be useful if you want to send latest state back to the MQTT client. Just check if incoming
* message has any length or not.
* Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
* (*) Address-layout is : [MQTT_BROKER_PREFIX]/[NodeID]/[SensorID]/V_[SensorType]
* NodeID and SensorID is uint8 (0-255) number.
* Last segment is translation of the sensor type, look inside MyMQTT.cpp for the definitions.
* User can change this to their needs. We have also left some space for custom types.
* Special: (sensor 255 reserved for special commands)
* You can receive a node sketch name with MyMQTT/20/255/V_Sketch_name (or version with _version)
* To-do:
* Special commands : clear or set EEPROM Values, Send REBOOT and Receive reboot for MyMQTT itself.
* Be able to send ACK so client returns the data being sent.
* ... Please come with ideas!
* What to do with publish messages.
* Test in more MQTT clients, So far tested in openhab and MyMQTT for Android (Not my creation)
* - http://www.openhab.org/
* - https://play.google.com/store/apps/details?id=at.tripwire.mqtt.client&hl=en
* ... Please notify me if you use this broker with other software.
* How to set-up Openhab and MQTTGateway:
* http://forum.mysensors.org/topic/303/mqtt-broker-gateway
#include <DigitalIO.h>
#include <SPI.h>
#include <MySigningNone.h>
#include <MyTransportRFM69.h>
#include <MyTransportNRF24.h>
#include <MyHwATMega328.h>
#include <MySigningAtsha204Soft.h>
#include <MySigningAtsha204.h>
#include <MySensor.h>
#include <MsTimer2.h>
#include <Ethernet.h>
#include "MyMQTT.h"
#include <EEPROM.h>
#define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
#define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button
// * Use this for IBOARD modded to use standard MISO/MOSI/SCK, see note *1 above!
#define RADIO_CE_PIN 3 // radio chip enable
#define RADIO_SPI_SS_PIN 8 // radio SPI serial select
#define RADIO_ERROR_LED_PIN A2 // Error led pin
#define RADIO_RX_LED_PIN A1 // Receive led pin
#define RADIO_TX_LED_PIN A0 // the PCB, on board LED
// * Use this for default configured pro mini / nano etc :
#define RADIO_CE_PIN 5 // radio chip enable
#define RADIO_SPI_SS_PIN 6 // radio SPI serial select
#define RADIO_ERROR_LED_PIN 7 // Error led pin
#define RADIO_RX_LED_PIN 8 // Receive led pin
#define RADIO_TX_LED_PIN 9 // the PCB, on board LED*/
#define TCP_PORT 1883 // Set your MQTT Broker Listening port.
IPAddress TCP_IP ( 192, 168, 1, 83 ); // Configure your static ip-address here
byte TCP_MAC[] = { 0x02, 0xDE, 0xAD, 0x00, 0x00, 0x42 }; // Mac-address - You should change this! see note *2 above!
// NRFRF24L01 radio driver (set low transmit power by default)
MyTransportNRF24 transport(RADIO_CE_PIN, RADIO_SPI_SS_PIN, RF24_PA_LEVEL_GW);
//MyTransportRFM69 transport;
// Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
//MySigningNone signer;
//MySigningAtsha204Soft signer;
//MySigningAtsha204 signer;
// Hardware profile
MyHwATMega328 hw;
// Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
MySensor gw(transport, hw /*, signer*/);
EthernetServer server = EthernetServer(TCP_PORT);
EthernetClient *currentClient = NULL;
MyMessage msg;
char convBuf[MAX_PAYLOAD*2+1];
char broker[] PROGMEM = MQTT_BROKER_PREFIX;
bool MQTTClientConnected = false;
uint8_t buffsize;
char buffer[MQTT_MAX_PACKET_SIZE];
volatile uint8_t countRx;
volatile uint8_t countTx;
volatile uint8_t countErr;
void writeEthernet(const char *writeBuffer, uint8_t *writeSize) {
#ifdef TCPDUMP
Serial.print(">>");
char buf[4];
for (uint8_t a=0; a<*writeSize; a++) { sprintf(buf,"%02X ",(uint8_t)writeBuffer[a]); Serial.print(buf); } Serial.println("");
#endif
server.write((const uint8_t *)writeBuffer, *writeSize);
void processEthernetMessages() {
char inputString[MQTT_MAX_PACKET_SIZE] = "";
byte inputSize = 0;
byte readCnt = 0;
byte length = 0;
EthernetClient client = server.available();
if (client) {
while (client.available()) {
// Save the current client we are talking with
currentClient = &client;
byte inByte = client.read();
readCnt++;
if (inputSize < MQTT_MAX_PACKET_SIZE) {
inputString[inputSize] = (char)inByte;
inputSize++;
if (readCnt == 2) {
length = (inByte & 127) * 1;
if (readCnt == (length+2)) {
break;
#ifdef TCPDUMP
Serial.print("<<");
char buf[4];
for (byte a=0; a<inputSize; a++) { sprintf(buf, "%02X ", (byte)inputString[a]); Serial.print(buf); } Serial.println();
#endif
processMQTTMessage(inputString, inputSize);
void incomingMessage(const MyMessage &message) {
rxBlink(1);
sendMQTT(message);
void setup()
Serial.print("Beginning setup");
//Wipe eprom
for (int i = 0 ; i < EEPROM.length() ; i++) {
EEPROM.write(i, 0);
Ethernet.begin(TCP_MAC, TCP_IP);
countRx = 0;
countTx = 0;
countErr = 0;
// Setup led pins
pinMode(RADIO_RX_LED_PIN, OUTPUT);
pinMode(RADIO_TX_LED_PIN, OUTPUT);
pinMode(RADIO_ERROR_LED_PIN, OUTPUT);
digitalWrite(RADIO_RX_LED_PIN, LOW);
digitalWrite(RADIO_TX_LED_PIN, LOW);
digitalWrite(RADIO_ERROR_LED_PIN, LOW);
// Set initial state of leds
digitalWrite(RADIO_RX_LED_PIN, HIGH);
digitalWrite(RADIO_TX_LED_PIN, HIGH);
digitalWrite(RADIO_ERROR_LED_PIN, HIGH);
// Add led timer interrupt
MsTimer2::set(300, ledTimersInterrupt);
MsTimer2::start();
// give the Ethernet interface a second to initialize
delay(1000);
// Initialize gateway at maximum PA level, channel 70 and callback for write operations
gw.begin(incomingMessage, 0, true, 0);
// start listening for clients
server.begin();
Serial.println("Ok!");
void loop()
gw.process();
processEthernetMessages();
inline MyMessage& build (MyMessage &msg, uint8_t destination, uint8_t sensor, uint8_t command, uint8_t type, bool enableAck) {
msg.destination = destination;
msg.sender = GATEWAY_ADDRESS;
msg.sensor = sensor;
msg.type = type;
mSetCommand(msg,command);
mSetRequestAck(msg,enableAck);
mSetAck(msg,false);
return msg;
char *getType(char *b, const char **index) {
char *q = b;
char *p = (char *)pgm_read_word(index);
while (*q++ = pgm_read_byte(p++));
*q=0;
return b;
void processMQTTMessage(char *inputString, uint8_t inputPos) {
char *str, *p;
uint8_t i = 0;
buffer[0]= 0;
buffsize = 0;
if ((uint8_t)inputString[0] >> 4 == MQTTCONNECT) {
buffer[buffsize++] = MQTTCONNACK << 4;
buffer[buffsize++] = 0x02; // Remaining length
buffer[buffsize++] = 0x00; // Connection accepted
buffer[buffsize++] = 0x00; // Reserved
MQTTClientConnected=true; // We have connection!
if ((uint8_t)inputString[0] >> 4 == MQTTPINGREQ) {
buffer[buffsize++] = MQTTPINGRESP << 4;
if ((uint8_t)inputString[0] >> 4 == MQTTSUBSCRIBE) {
buffer[buffsize++] = MQTTSUBACK << 4; // Just ack everything, we actually dont really care!
buffer[buffsize++] = 0x03; // Remaining length
buffer[buffsize++] = (uint8_t)inputString[2]; // Message ID MSB
buffer[buffsize++] = (uint8_t)inputString[3]; // Message ID LSB
buffer[buffsize++] = MQTTQOS0; // QOS level
if ((uint8_t)inputString[0] >> 4 == MQTTUNSUBSCRIBE) {
buffer[buffsize++] = MQTTUNSUBACK << 4;
if ((uint8_t)inputString[0] >> 4 == MQTTDISCONNECT) {
MQTTClientConnected=false; // We lost connection!
if (buffsize > 0) {
writeEthernet(buffer,&buffsize);
// We publish everything we get, we dont care if its subscribed or not!
if ((uint8_t)inputString[0] >> 4 == MQTTPUBLISH || (MQTT_SEND_SUBSCRIPTION && (uint8_t)inputString[0] >> 4 == MQTTSUBSCRIBE)) {
buffer[0]= 0;
buffsize = 0;
// Cut out address and payload depending on message type.
strncat(buffer,inputString+6,inputString[5]);
} else {
strncat(buffer,inputString+4,inputString[3]);
#ifdef DEBUG
Serial.println(buffer);
#endif
// TODO: Check if we should send ack or not.
for (str = strtok_r(buffer,"/",&p) ; str && i<4 ; str = strtok_r(NULL,"/",&p)) {
if (i == 0) {
if (strcmp_P(str,broker)!=0) { //look for MQTT_BROKER_PREFIX
return; //Message not for us or malformatted!
} else if (i==1) {
msg.destination = atoi(str); //NodeID
} else if (i==2) {
msg.sensor = atoi(str); //SensorID
} else if (i==3) {
char match=255; //SensorType
#ifdef MQTT_TRANSLATE_TYPES
for (uint8_t j=0; strcpy_P(convBuf, (char*)pgm_read_word(&(vType[j]))) ; j++) {
if (strcmp((char*)&str[2],convBuf)==0) { //Strip V_ and compare
match=j;
break;
if (j >= V_TOTAL) break;
#endif
if ( atoi(str)!=0 || str=="0" ) {
match=atoi(str);
if (match==255) {
match=V_UNKNOWN;
msg.type = match;
i++;
} //Check if packge has payload
if ((uint8_t)inputString[1] > (uint8_t)(inputString[3]+2) && !((uint8_t)inputString[0] >> 4 == MQTTSUBSCRIBE)) {
strcpy(convBuf,inputString+(inputString[3]+4));
msg.set(convBuf); //Payload
} else {
msg.set(""); //No payload
txBlink(1);
if (!gw.sendRoute(build(msg, msg.destination, msg.sensor, C_SET, msg.type, 0))) errBlink(1);
void sendMQTT(const MyMessage &inMsg) {
MyMessage msg = inMsg;
buffsize = 0;
if (!MQTTClientConnected) return; //We have no connections - return
if (msg.isAck()) {
// if (msg.sender==255 && mGetCommand(msg)==C_INTERNAL && msg.type==I_ID_REQUEST) {
// TODO: sending ACK request on id_response fucks node up. doesn't work.
// The idea was to confirm id and save to EEPROM_LATEST_NODE_ADDRESS.
} else {
// we have to check every message if its a newly assigned id or not.
// Ack on I_ID_RESPONSE does not work, and checking on C_PRESENTATION isn't reliable.
uint8_t newNodeID = gw.loadState(EEPROM_LATEST_NODE_ADDRESS)+1;
if (newNodeID <= MQTT_FIRST_SENSORID) newNodeID = MQTT_FIRST_SENSORID;
if (msg.sender==newNodeID) {
gw.saveState(EEPROM_LATEST_NODE_ADDRESS,newNodeID);
if (mGetCommand(msg)==C_INTERNAL) {
if (msg.type==I_CONFIG) {
txBlink(1);
if (!gw.sendRoute(build(msg, msg.sender, 255, C_INTERNAL, I_CONFIG, 0).set(MQTT_UNIT))) errBlink(1);
return;
} else if (msg.type==I_ID_REQUEST && msg.sender==255) {
if (newNodeID >= MQTT_LAST_SENSORID) return; // Sorry no more id's left :(
txBlink(1);
if (!gw.sendRoute(build(msg, msg.sender, 255, C_INTERNAL, I_ID_RESPONSE, 0).set(newNodeID))) errBlink(1);
return;
if (mGetCommand(msg)!=C_PRESENTATION) {
if (mGetCommand(msg)==C_INTERNAL) msg.type=msg.type+(S_FIRSTCUSTOM-10); //Special message
buffer[buffsize++] = MQTTPUBLISH << 4; // 0:
buffer[buffsize++] = 0x09; // 1: Remaining length with no payload, we'll set this later to correct value, buffsize -2
buffer[buffsize++] = 0x00; // 2: Length MSB (Remaing length can never exceed ff,so MSB must be 0!)
buffer[buffsize++] = 0x08; // 3: Length LSB (ADDR), We'll set this later
strcpy_P(buffer+4, broker);
buffsize+=strlen_P(broker);
if (msg.type > V_TOTAL) msg.type=V_UNKNOWN;// If type > defined types set to unknown.
buffsize+=sprintf(&buffer[buffsize],"/%i/%i/V_%s",msg.sender,msg.sensor,getType(convBuf, &vType[msg.type]));
#else
buffsize+=sprintf(&buffer[buffsize],"/%i/%i/%i",msg.sender,msg.sensor,msg.type);
#endif
buffer[3]=buffsize-4; // Set correct address length on byte 4.
#ifdef DEBUG
Serial.println((char*)&buffer[4]);
#endif
msg.getString(convBuf);
for (uint8_t a=0; a<strlen(convBuf); a++) {// Payload
buffer[buffsize++] = convBuf[a];
buffer[1]=buffsize-2; // Set correct Remaining length on byte 2.
void ledTimersInterrupt() {
if(countRx && countRx != 255) {
// switch led on
} else if(!countRx) {
// switching off
if(countRx != 255) { countRx--; }
if(countTx && countTx != 255) {
// switch led on
} else if(!countTx) {
// switching off
if(countTx != 255) { countTx--; }
if(countErr && countErr != 255) {
// switch led on
} else if(!countErr) {
// switching off
if(countErr != 255) { countErr--; }
void rxBlink(uint8_t cnt) {
if(countRx == 255) { countRx = cnt; }
void txBlink(uint8_t cnt) {
if(countTx == 255) { countTx = cnt; }
void errBlink(uint8_t cnt) {
if(countErr == 255) { countErr = cnt; }
Motion Sensor Sketch with Callback
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* DESCRIPTION
* Motion Sensor example using HC-SR501
* http://www.mysensors.org/build/motion
#include <EEPROM.h>
#include <SPI.h>
unsigned long SLEEP_TIME = 30000; // Sleep time between reports (in milliseconds)
#define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
#define NODE_ID 2
#define CHILD_ID 2 // Id of the sensor child
#define LED_PIN 6
MySensor gw;
// Initialize motion message
MyMessage msg(CHILD_ID, V_LIGHT);
void setup()
//Wipe eprom
EEPROM.write(i, 0);
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW);
gw.begin(incomingMessage, NODE_ID, false);
// Send the sketch version information to the gateway and Controller
gw.sendSketchInfo("Motion Sensor", "1.0");
pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
// Register all sensors to gw (they will be created as child devices)
gw.present(CHILD_ID, S_LIGHT);
void loop()
// Read digital motion value
boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
Serial.println(tripped);
gw.send(msg.set(tripped?"1":"0")); // Send tripped value to gw
// Sleep until interrupt comes in on motion sensor. Send update every two minute.
gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
digitalWrite(LED_PIN, HIGH);
Serial.println("message received");
OpenHab.cfg
mqtt:mysensor.url=tcp://192.168.1.83:1883
mqtt:mysensor.clientId=openhab
OpenHab MQTT.items
Switch MQTTTestSwitch "MQTT Test Switch" (gBasement) {mqtt=">[mysensor:MyMQTT/2/2/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/2/2/V_LIGHT:command:OFF:0],<[mysensor:MyMQTT/2/2/V_LIGHT:command:MAP(1on0off.map)]"}
OpenHab MQTT.log on startup
2016-07-25 22:39:53.851 [DEBUG] [.io.transport.mqtt.MqttService:123 ]- Starting MQTT Service...
2016-07-25 22:39:54.506 [INFO ] [.io.transport.mqtt.MqttService:108 ]- MQTT Service initialization completed.
2016-07-25 22:39:54.534 [INFO ] [o.i.t.m.i.MqttBrokerConnection:114 ]- Starting MQTT broker connection 'mysensor'
2016-07-25 22:39:54.613 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:294 ]- Creating new client for 'tcp://192.168.1.83:1883' using id 'openhab' and file store '/tmp/mysensor'
2016-07-25 22:42:40.296 [DEBUG] [.b.mqtt.internal.MqttActivator:34 ]- MQTT binding has been started.
2016-07-25 22:42:41.142 [TRACE] [m.i.MqttGenericBindingProvider:52 ]- Starting to load MQTT config for item MQTTTestSketchName
2016-07-25 22:42:41.162 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ]- Loaded MQTT config for item 'MQTTTestSketchName' : 1 subscribers, 0 publishers
2016-07-25 22:42:41.176 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ]- Starting message consumer for broker 'mysensor' on topic 'MyMQTT/2/255/V_SKETCH_NAME'
2016-07-25 22:42:41.207 [TRACE] [m.i.MqttGenericBindingProvider:52 ]- Starting to load MQTT config for item MQTTTestSketchVersion
2016-07-25 22:42:41.225 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ]- Loaded MQTT config for item 'MQTTTestSketchVersion' : 1 subscribers, 0 publishers
2016-07-25 22:42:41.237 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ]- Starting message consumer for broker 'mysensor' on topic 'MyMQTT/2/255/V_SKETCH_VERSION'
2016-07-25 22:42:41.272 [TRACE] [m.i.MqttGenericBindingProvider:52 ]- Starting to load MQTT config for item MQTTTestSwitch
2016-07-25 22:42:41.301 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ]- Loaded MQTT config for item 'MQTTTestSwitch' : 1 subscribers, 2 publishers
2016-07-25 22:42:41.308 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ]- Starting message consumer for broker 'mysensor' on topic 'MyMQTT/2/2/V_LIGHT'
2016-07-25 22:42:53.947 [DEBUG] [.mqtt.internal.MqttItemBinding:44 ]- Publishing command ON to MyMQTT/2/2/V_LIGHT
2016-07-25 22:42:54.184 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:437 ]- Publishing message 5 to topic 'MyMQTT/2/2/V_LIGHT'
2016-07-25 22:43:03.672 [DEBUG] [.mqtt.internal.MqttItemBinding:44 ]- Publishing command OFF to MyMQTT/2/2/V_LIGHT
2016-07-25 22:43:03.795 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:437 ]- Publishing message 6 to topic 'MyMQTT/2/2/V_LIGHT'
OpenHab Events.log on MySensor startup
2016-07-25 23:42:22 - MQTTTestSketchName state updated to Motion Sensor
2016-07-25 23:42:22 - MQTTTestSketchVersion state updated to 1.0
2016-07-25 23:42:22 - MQTTTestSwitch received command ON
