I got a Fibaro FGSS001 smoke sensor that I can’t get working.
It’s reported as a FGSS101 in HABmin. Don’t know if that matters but it doesn’t work for me. Neither temperature nor tampering is working (It was working earlier with OH1. Also tried OH2 earlier and it worked then as well).
I get these warning/error messages.
2016-12-23 12:17:23.476 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Unknown command class 0x91
2016-12-23 12:17:23.478 [ERROR] [ssage.ApplicationCommandMessageClass] - NODE 13: Unsupported zwave command class MANUFACTURER_PROPRIETARY (0x91)
Tried deleting the xml file for node13 but that didn’t change anything.
I read something about FGSS101 losing its channels but that was 20 days ago. I did a fresh (snapshot) install 8 days ago (and I did an apt-get just a few days ago) so I assume that it doesn’t affect me.
*.items
Number FGSS001_1_temp "FGSS001_1 - Temperature [%.1f C]" <temperature> (temp) { channel="zwave:device:15912e68c95:node13:sensor_temperature" }
Number FGSS001_1_batt "FGSS001_1 - Battery Level [%d %%]" <battery> (batt) { channel="zwave:device:15912e68c95:node13:battery-level" }
Contact FGSS001_1_alSmoke "FGSS001_1 - Smoke Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_smoke" }
Contact FGSS001_1_alTamp "FGSS001_1 - Tamperig Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_general" }
Contact FGSS001_1_alHeat "FGSS001_1 - Heat Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_heat" }
Ideas?
