hi ,
i have started to move from OH1 to OH 2.
I have all my things runnning and now i would like to get persitence and charts running.
I used the following mapdb persistence mapdb.persist file
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every5Minutes : "0 */5 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
// persist all items on every change and every minute and restore them from the db at startup
Phase1Leistung,Phase2Leistung,Phase3Leistung,TotalLeistung : strategy = everyChange, everyMinute
mapdb.cfg looks like this:
# the commit interval in seconds (optional, default to '5')
commitinterval=5
# issue a commit even if the state did not change (optional, defaults to 'false')
commitsamestate=true
I have an item called Phase1Leistung which is been calculated and updated in a rule
19:03:58.598 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Phase1Leistung
19:03:58.599 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored ‘Phase1Leistung’ with state
’1177.89’ in mapdb database
i verify in the REST API if data are available
"name": "Phase1Leistung",
"datapoints": "3",
"data": [
"time": 1496768710640,
"state": "1175.52"
"time": 1496855100004,
"state": "1175.52"
"time": 1496855110640,
"state": "1175.52"
So i assume that the data are now been stored in mapdb persitence and i can start making a chart.
In Habmin i configured configuration -> system -> services -> persistence if mapdb is my default persistence.
After that i open configuration -> system -> persistence to verify if habmin can see the data.
Unfortunatley i can not see any of the item been store in habmin
In the charteditor i can select the item but no data are shown.
Anything i am doing wrong in above configuration?
Is there anything else to verify ?
Thx
Peter
