Hello
I’m not shure, if this is binding related or anopenhab problem.
I am using the mysensors binding: https://github.com/tobof/openhab2-addons/tree/MySensors/addons/binding/org.openhab.binding.mysensors
But i don*t see any values in openhab.
This is what i have:
Startup of openhab:
2016-06-06 07:12:08.483 [DEBUG] [org.openhab.binding.mysensors ] - BundleEvent STARTING - org.openhab.binding.mysensors
2016-06-06 07:12:08.550 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.MySensorsHandlerFactory, component.id=7, service.id=102, service.bundleid=11, service.scope=bundle} - org.openhab.binding.mysensors
2016-06-06 07:12:09.070 [DEBUG] [org.openhab.binding.mysensors ] - BundleEvent STARTED - org.openhab.binding.mysensors
2016-06-06 07:12:12.062 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2016-06-06 07:12:18.694 [ERROR] [org.openhab.ui.habmin ] - [org.openhab.ui.habmin.designer(3)] bind method [setItemRegistry] not found; Component will fail
2016-06-06 07:12:18.702 [ERROR] [org.openhab.ui.habmin ] - [org.openhab.ui.habmin.designer(3)] bind method [setItemRegistry] not found
2016-06-06 07:12:25.252 [ERROR] [org.eclipse.smarthome.core.transform] - [org.eclipse.smarthome.action.transformation.action(51)] Circular reference detected, getService returning null
2016-06-06 07:12:39.288 [INFO ] [rthome.event.ItemThingLinkAddedEvent] - Link 'mysensors_light_gateway_Light_1_0-mysensors:light:gateway:Light_1_0' has been added.
2016-06-06 07:12:39.315 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'home_group_88a3d2a1' has been added.
2016-06-06 07:12:42.030 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-06-06 07:12:42.261 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-06-06 07:12:42.825 [WARN ] [sql.internal.MysqlPersistenceService] - The SQL user is missing - please configure the sql:user parameter in openhab.cfg
2016-06-06 07:12:43.071 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-06-06 07:12:43.114 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2016-06-06 07:12:43.470 [INFO ] [.openhab.core.internal.CoreActivator] - openHAB runtime has been started (v2.0.0, build b2).
2016-06-06 07:12:43.479 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2016-06-06 07:12:44.159 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
2016-06-06 07:12:44.397 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'mysensors:bridge-eth:gateway' has been added.
2016-06-06 07:12:44.468 [INFO ] [nsors.handler.MySensorsBridgeHandler] - Using Metric measure unit
2016-06-06 07:12:44.470 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Set skip check on startup to: false
2016-06-06 07:12:44.489 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=278, service.bundleid=11, service.scope=singleton} - org.openhab.binding.mysensors
2016-06-06 07:12:44.527 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors Bridge
2016-06-06 07:12:44.531 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from UNINITIALIZED to INITIALIZING
2016-06-06 07:12:44.540 [DEBUG] [rs.protocol.ip.MySensorsIpConnection] - Connecting to bridge ...
2016-06-06 07:12:44.762 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
2016-06-06 07:12:44.770 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
2016-06-06 07:12:44.776 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;11;EthernetGateway
2016-06-06 07:12:44.778 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;12;1.0
2016-06-06 07:12:44.849 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;2;2.0.0-beta
2016-06-06 07:12:44.852 [DEBUG] [s.internal.MySensorsBridgeConnection] - Good,Gateway is up and running! (Ver:2.0.0-beta)
2016-06-06 07:12:44.858 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=mysensors:bridge-eth, thing.id=mysensors:bridge-eth:gateway, service.id=279, service.bundleid=11, service.scope=singleton} - org.openhab.binding.mysensors
2016-06-06 07:12:44.859 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from INITIALIZING to ONLINE
2016-06-06 07:12:44.900 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
2016-06-06 07:12:44.990 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2016-06-06 07:12:45.047 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2016-06-06 07:12:45.168 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c0-mysensors:light:gateway:n1c0:status' has been added.
2016-06-06 07:12:45.171 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c1-mysensors:light:gateway:n1c1:status' has been added.
2016-06-06 07:12:45.174 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c2-mysensors:humidity:gateway:n1c2:hum' has been added.
2016-06-06 07:12:45.178 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c3-mysensors:humidity:gateway:n1c3:hum' has been added.
2016-06-06 07:12:45.182 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c4-mysensors:humidity:gateway:n1c4:hum' has been added.
2016-06-06 07:14:50.818 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
2016-06-06 07:14:50.820 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
2016-06-06 07:14:55.831 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
2016-06-06 07:14:55.832 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
2016-06-06 07:28:01.373 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
2016-06-06 07:28:01.375 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
2016-06-06 07:28:06.385 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
2016-06-06 07:28:06.387 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
2016-06-06 07:32:21.567 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
2016-06-06 07:32:21.568 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
2016-06-06 07:32:26.578 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
2016-06-06 07:32:26.582 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
This suggest me, that the binding itself is working. The links from my .things file are added also.
my.things:
mysensors:bridge-eth:gateway [ ipAddress="192.168.100.10", tcpPort=5003, sendDelay=200 ] {
/** define things connected to that bridge here */
light n1c0 [ nodeId="1", childId="0", requestAck=true ]
light n1c1 [ nodeId="1", childId="1", requestAck=true ]
humidity n1c2 [ nodeId="1", childId="2" ]
humidity n1c3 [ nodeId="1", childId="3" ]
humidity n1c4 [ nodeId="1", childId="4" ]
And here my items:
Switch n1c0 "PFLANZENNAME1 Pumpe" <water> (gGF_irrigation01) { channel="mysensors:light:gateway:n1c0:status" }
Switch n1c1 "PFLANZENNAME1 Pumpe Automatikmodus" <water> (gGF_irrigation01) { channel="mysensors:light:gateway:n1c1:status" }
Number n1c2 "PFLANZENNAME1 Bodenfeuchtigkeit max" <water> (gGF_irrigation01) { channel="mysensors:humidity:gateway:n1c2:hum" }
Number n1c3 "PFLANZENNAME1 Bodenfeuchtigkeit min" <water> (gGF_irrigation01) { channel="mysensors:humidity:gateway:n1c3:hum" }
Number n1c4 "PFLANZENNAME1 Bodenfeuchtigkeit" <water> (gGF_irrigation01,gGF_eating) { channel="mysensors:humidity:gateway:n1c4:hum" }
This are changes reported by the mysensors network:
2016-06-06 19:51:03.336 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
2016-06-06 19:51:03.338 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
2016-06-06 19:51:08.350 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
2016-06-06 19:51:08.352 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
but i don’t see any changes to the items in the logfile and in the frontend there are simple no values behind the strings.
Any idea whats wrong here?
Greetings
Dakky
