OpenHAB: v2.5.0.M1 = Milestone 1
Docker Container: amd64.debian
Hardware: x86_64 Synology NAS
Does anyone has an idea what throws this error message (actually it is just a warning but looks frightening )? Can I ignore it or can/should it be solved?
Thanks for any advice!!!
Cheers Justus
12:41:09.635 [WARN ] [org.eclipse.jetty.server.HttpChannel ] - /rest/items
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_3,4,1770150513) has been shut down
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.Server.handle(Server.java:503) ~[84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:364) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683) [87:org.eclipse.jetty.util:9.4.12.v20180830]
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1340) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1242) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 15 more
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions. They are:
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 15 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_3,4,1770150513) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
... 15 more
