Cant install Homegear on openHABian
To try out openHAB, i used the latest openhabian version ( and tried to install homegear with the inbuilt menu. That apperently didnt work and I tried to install it manually as described on the homegear page.
Hardware: RPI2 and 16GB card
Version: openhabianpi-raspbian-20170318-git9767b24-crc9616e8a1.img.xz
sudo apt install apt-transport-https
sudo wget https://homegear.eu/packages/Release.key && sudo apt-key add Release.key && sudo rm Release.key
sudo echo 'deb https://homegear.eu/packages/Raspbian/ jessie/' >> /etc/apt/sources.list.d/homegear.list
sudo apt update
sudo apt install homegear homegear-nodes-core
But im getting these error messages after sudo apt update:
Ign http://repos.azulsystems.com stable InRelease
Hit http://repos.azulsystems.com stable Release.gpg
Hit http://mirrordirector.raspbian.org jessie InRelease
Ign http://dl.bintray.com stable InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Hit https://homegear.eu jessie/ InRelease
Get:1 http://dl.bintray.com stable Release.gpg [821 B]
Get:2 http://repos.azulsystems.com stable/main armhf Packages [1,339 B]
Get:3 http://dl.bintray.com stable Release [6,050 B]
Get:4 https://homegear.eu jessie/ Packages
Get:5 http://dl.bintray.com stable/main armhf Packages [666 B]
Ign http://repos.azulsystems.com stable/main Translation-en_US
Ign http://repos.azulsystems.com stable/main Translation-en_US.UTF-8
Get:6 https://homegear.eu jessie/ Translation-en_US [232 B]
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Get:7 https://homegear.eu jessie/ Translation-en [229 B]
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Get:8 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:9 https://homegear.eu jessie/ Packages [27.6 kB]
Get:10 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:11 https://homegear.eu jessie/ Translation-en [229 B]
Get:12 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US.UTF-8
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US
Ign http://archive.raspberrypi.org jessie/main Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US.UTF-8
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US
Ign http://archive.raspberrypi.org jessie/main Translation-en_US.UTF-8
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US.UTF-8
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_US.UTF-8
Ign http://dl.bintray.com stable/main Translation-en_US
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US.UTF-8
Ign http://dl.bintray.com stable/main Translation-en_US.UTF-8
Get:13 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:14 https://homegear.eu jessie/ Translation-en [229 B]
Get:15 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:16 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:17 https://homegear.eu jessie/ Translation-en [229 B]
Get:18 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:19 https://homegear.eu jessie/ Translation-en_US [232 B]
Ign https://homegear.eu jessie/ Translation-en_US
Get:20 https://homegear.eu jessie/ Translation-en [229 B]
Get:21 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Ign https://homegear.eu jessie/ Translation-en_US.UTF-8
Fetched 36.5 kB in 20s (1,786 B/s)
W: Failed to fetch https://homegear.eu/packages/Raspbian/jessie/Packages  Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
I’ve no idea how to deal with the sum mismatch. Im fairly new to this topic so help would be greatly appreciated
Thanks!
Just remove all the content of /var/lib/apt/lists directory:
sudo rm -rf /var/lib/apt/lists/*
then run:
sudo apt-get update
Source: https://askubuntu.com/questions/41605/trouble-downloading-packages-list-due-to-a-hash-sum-mismatch-error
I have the same problem but removing the lists doesn’t solve it. Does anyone else has a hint how to solve it?
As far as I can see, this is a problem with their repository. Please contact https://forum.homegear.eu and let us know of the result!
I made it finally…:
  1. wget https://homegear.eu/packages/Raspbian/jessie/libhomegear-node_0.1.0-1_armhf.deb
  2. dpkg -i libhomegear-node_0.1.0-1_armhf.deb
  3. apt-get update --fix-missing
  4. openhabian-config (==> 21 | Optional: Homegear)
Now homegear works…
Should be solved by now: Fehlschlag beim holen von ... Größe stimmt nicht überein - #2 by sathya - Installation - Homegear Forum
I am facing the same issue. I am using openhabian and OH2.1 stable. When trying to install homegear via openhabian-config, I still receive the error messages mentioned by @MaxH:
Fetched 4,070 B in 7s (520 B/s)
W: Failed to fetch https://homegear.eu/packages/Raspbian/jessie/Packages  HttpError403
FAILED
@cptPH suggestion is also not working on my side.
Using @Ronin-Jay solution stops working with the very first line of code:
[22:08:09] openhabian@openHABianPi:/$ wget https://homegear.eu/packages/Raspbian/jessie/libhomegear-node_0.1.0-1_armhf.deb
--2017-08-26 22:08:14--  https://homegear.eu/packages/Raspbian/jessie/libhomegear-node_0.1.0-1_armhf.deb
Resolving homegear.eu (homegear.eu)... 138.201.146.201, 2a01:4f8:172:19a5::3
Connecting to homegear.eu (homegear.eu)|138.201.146.201|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2017-08-26 22:08:15 ERROR 403: Forbidden.
So, can anyone replicate this scenario, and even more important, how can I solve that issue?
If in doubt, follow the official homegear instructions…
https://doc.homegear.eu/data/homegear/installation.html#raspbian-8-jessie
That solved the issue! Thanks!
Hello together,
I am faceing same issues, trying to install homegear via openhabian-config brings me:
[19:56:29] openhabian@openHABianPi:~$ sudo openhabian-config
[sudo] password for openhabian:
2017-09-17_19:56:45_CEST [openHABian] Checking for root privileges... OK
2017-09-17_19:56:45_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2017-09-17_19:56:52_CEST [openHABian] Setting up the Homematic CCU2 emulation software Homegear... --2017-09-17 19:56:52--  http://homegear.eu/packages/Release.key
Connecting to homegear.eu (homegear.eu)|138.201.146.201|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://relaunch.homegear.eu/packages/Release.key [following]
--2017-09-17 19:56:52--  https://relaunch.homegear.eu/packages/Release.key
Resolving relaunch.homegear.eu (relaunch.homegear.eu)... 138.201.146.201, 2a01:4f8:172:19a5::3
Connecting to relaunch.homegear.eu (relaunch.homegear.eu)|138.201.146.201|:443... connected.
Location: https://homegear.eu/packages/Release.key [following]
--2017-09-17 19:56:52--  https://homegear.eu/packages/Release.key
HTTP request sent, awaiting response... 200 OK
Length: 3125 (3.1K) [application/pgp-keys]
Saving to: ‘STDOUT’
-                                         100%[====================================================================================>]   3.05K  --.-KB/s   in 0s
2017-09-17 19:56:52 (9.15 MB/s) - written to stdout [3125/3125]
OK
$ apt update
Hit http://dl.bintray.com stable Release.gpg
Hit https://deb.nodesource.com jessie InRelease
Get:1 https://deb.nodesource.com jessie/main Sources [763 B]
Get:2 https://deb.nodesource.com jessie/main armhf Packages [976 B]
Get:3 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:4 http://dl.bintray.com stable/main armhf Packages [992 B]
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:6 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:7 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:8 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:9 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:10 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://homegear.eu jessie/ Packages
Get:13 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:14 http://repos.azulsystems.com stable/main armhf Packages [1,339 B]
Get:15 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:16 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:18 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:19 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:20 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:21 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:22 https://homegear.eu jessie/ Packages [56.4 kB]
Ign https://deb.nodesource.com jessie/main Translation-en_US
Get:23 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:24 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en_US.UTF-8
Get:25 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:26 https://homegear.eu jessie/ Translation-en [229 B]
Get:27 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:28 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:29 https://homegear.eu jessie/ Translation-en [229 B]
Get:30 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:31 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:32 https://homegear.eu jessie/ Translation-en [229 B]
Get:33 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:34 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:35 https://homegear.eu jessie/ Translation-en [229 B]
Get:36 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Fetched 60.4 kB in 25s (2,402 B/s)
FAILED
following https://doc.homegear.eu/data/homegear/installation.html#raspbian-8-jessie
give a the end:
[20:01:04] openhabian@openHABianPi:~$ sudo apt install apt-transport-https
Reading package lists... Done
Building dependency tree
apt-transport-https is already the newest version.
The following package was automatically installed and is no longer required:
  triggerhappy
Use 'apt-get autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[20:01:30] openhabian@openHABianPi:~$ sudo wget https://homegear.eu/packages/Release.key && sudo apt-key add Release.key && sudo rm Release.key
--2017-09-17 20:01:48--  https://homegear.eu/packages/Release.key
Saving to: ‘Release.key’
Release.key                               100%[====================================================================================>]   3.05K  --.-KB/s   in 0s
2017-09-17 20:01:48 (9.02 MB/s) - ‘Release.key’ saved [3125/3125]
OK
[20:01:58] openhabian@openHABianPi:~$ sudo echo 'deb https://homegear.eu/packages/Raspbian/ jessie/' >> sudo /etc/apt/sources.list.d/homegear.list
[20:02:06] openhabian@openHABianPi:~$ sudo apt update
Get:1 https://homegear.eu jessie/ Packages
Get:2 https://deb.nodesource.com jessie/main Sources [763 B]
Get:3 https://deb.nodesource.com jessie/main armhf Packages [976 B]
Get:4 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:5 http://dl.bintray.com stable/main armhf Packages [992 B]
Get:7 http://repos.azulsystems.com stable/main armhf Packages [1,339 B]
Get:9 https://homegear.eu jessie/ Translation-en [229 B]
Get:10 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:14 https://homegear.eu jessie/ Packages [56.4 kB]
Get:15 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:17 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:18 https://homegear.eu jessie/ Translation-en [229 B]
Get:19 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:20 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:21 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:22 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:23 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:24 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:25 https://homegear.eu jessie/ Translation-en [229 B]
Get:26 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:27 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:28 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:29 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:30 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:31 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Fetched 59.4 kB in 10s (5,516 B/s)
[20:02:29] openhabian@openHABianPi:~$ sudo apt install homegear
E: Unable to locate package homegear
[20:03:12] openhabian@openHABianPi:~$
Can you help me ?
Hello everyone,
same issues here, no way to install homegear on a Raspberry Pi 2B.
Any ideas how to solve this ?
2017-09-18_10:02:45_CEST [openHABian] Checking for root privileges... OK
2017-09-18_10:02:45_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2017-09-18_10:02:48_CEST [openHABian] Updating myself... OK - No remote changes detected. You are up to date!
2017-09-18_10:02:55_CEST [openHABian] Setting up the Homematic CCU2 emulation software Homegear... --2017-09-18 10:02:55--  http://homegear.eu/packages/Release.key
--2017-09-18 10:02:55--  https://relaunch.homegear.eu/packages/Release.key
--2017-09-18 10:02:56--  https://homegear.eu/packages/Release.key
Saving to: ‘STDOUT’
-                                100%[============================================================>]   3.05K  --.-KB/s   in 0.001s
2017-09-18 10:02:56 (4.19 MB/s) - written to stdout [3125/3125]
OK
$ apt update
Hit http://repo.mosquitto.org jessie InRelease
Get:1 https://dl.bintray.com stable InRelease
Ign https://dl.bintray.com stable InRelease
Hit https://dl.bintray.com stable Release.gpg
Get:3 https://homegear.eu jessie/ Packages
Get:4 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:5 https://homegear.eu jessie/ Translation-en [229 B]
Get:6 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:7 https://homegear.eu jessie/ Packages [56.4 kB]
Get:8 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:9 https://deb.nodesource.com jessie/main Sources [763 B]
Get:10 https://homegear.eu jessie/ Translation-en [229 B]
Get:11 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Hit http://repo.mosquitto.org jessie/main armhf Packages
Get:12 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:13 https://homegear.eu jessie/ Translation-en [229 B]
Get:14 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:16 https://deb.nodesource.com jessie/main armhf Packages [976 B]
Get:17 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:22 https://dl.bintray.com stable/main Translation-en_US
Ign http://repo.mosquitto.org jessie/main Translation-en_US
Get:24 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:25 https://dl.bintray.com stable/main Translation-en
Get:27 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign http://repo.mosquitto.org jessie/main Translation-en_US.UTF-8
Get:28 https://dl.bintray.com stable/main Translation-en_US.UTF-8
Get:29 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:30 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:31 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:32 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit https://dl.bintray.com stable/main armhf Packages
Get:33 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:34 https://dl.bintray.com stable/main Translation-en_US
Get:35 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:36 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:37 https://dl.bintray.com stable/main Translation-en
Get:38 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:39 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:40 https://dl.bintray.com stable/main Translation-en_US.UTF-8
Get:41 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:42 https://dl.bintray.com stable/main Translation-en_US
Get:43 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
Get:44 https://dl.bintray.com stable/main Translation-en
Get:45 https://dl.bintray.com stable/main Translation-en_US.UTF-8
Get:46 https://dl.bintray.com stable/main Translation-en_US
Get:47 https://dl.bintray.com stable/main Translation-en
Get:48 https://dl.bintray.com stable/main Translation-en_US.UTF-8
Get:49 https://dl.bintray.com stable/main Translation-en_US
Ign https://dl.bintray.com stable/main Translation-en_US
Get:50 https://dl.bintray.com stable/main Translation-en
Get:51 https://dl.bintray.com stable/main Translation-en_US.UTF-8
Ign https://dl.bintray.com stable/main Translation-en_US.UTF-8
Fetched 59.4 kB in 21s (2,822 B/s)
FAILED
Thanks for your support- any hint is appreciated.
Seems to be the same error once again. Probably the repository is out of sync again. Just wait a few hours and it will eventually be fixed. Not sure if one needs to inform them…
Ive just posted in the homegear forum :
https://forum.homegear.eu/t/Hash-Sum-mismatch-openhabian/1462
