Can't install influxdb + Grafana
Tags: #<Tag:0x00007faf8e0a0d80> #<Tag:0x00007faf8e0a0cb8> #<Tag:0x00007faf8e0a0bf0>
Hello
I cant install influxdb + Grafana. I have tried many times with a completely newly installed openhabian. I have tried with Pi 4b and Pi 3b+ and I have even tried to downgrade it to 2.4 but the installation but I always get this message:
“Sadly there was a problem setting up the selected │
│ option. Please report this problem in the openHAB │
│ community forum or as a openHABian GitHub issue.”
And its stop at the same place:
BlockquoteProcessing triggers for dbus (1.12.16-1) …
Updating FireMotD available updates count …
$ systemctl daemon-reload
$ systemctl enable grafana-server.service
Failed to enable unit: Too many levels of symbolic links
$ systemctl start grafana-server.service
OK
Resetting Grafana admin password…
$ grafana-cli admin reset-admin-password admin
/opt/openhabian/functions/helpers.bash: line 24: grafana-cli: command not found
FAILED Connection Grafana to InfluxDB…{“message”:"Invalid username or password "}Adding openHAB dashboard tile for Grafana… 2020-05-16_09:35:28_CEST [openHAB ian] Adding an openHAB dashboard tile for ‘grafana’… OK
Adding install InfluxDB with database configuration to openHAB
$ touch /etc/openhab2/services/influxdb.cfg
2020-05-16_09:36:39_CEST [openHABian] Updating Linux package information … 202
I have used influxdb +Grafana on openhab before but when I this week tried to restart the whole project I failed to install it.
Any suggestions? Can I do it manually with a older version but still setup nicely at openhab:3000?
Best regards
David
I’ve got the same situation - Pi3B+ and OpenHabian. I’ve tried to install FireMotD but there is an error while I’m doing this - the same situation like:
Can anyone help? Thank you in advance!
looks like the service already was enabled before
Otherwise this would not result in OK
which version of grafana package is installed ?
A version that is being provided by the OS itself or the version that is installed by openhabian script?
I followed the steps described here to install influx + grafana as I am not using openhabian and I also had to use a different port than 3000.
This looks like you installed two grafana packages ( grafana-2.6.0+dfsg-3+b1 and grafana-data ) that are being provided by the OS. openhabian tries to install grafana-5.1.4 from the grafana repository.
I suggest to try to remove the OS packages before trying to run openhabian to install.
Openhabian added the grafana repository in /etc/apt/sources.list.d/ thus the manual installation also will try to overwrite the systems package.
I have only tried using the auto install in openhabian-config. I have more than 5 times installed a clean openhabian then tried installing it but get the same error. On diffrent RPi and SD cards.
/David
Neverthless I would be interested to see which version is installed. Could you check:
dpkg -l | grep grafana
OK
[> 15:26:43] openhabian@openhab:~$ dpkg -l | grep grafana
ii grafana 2.6.0+dfsg-3+b1 arm hf feature rich metrics dashboard and graph editor
ii grafana-data 2.6.0+dfsg-3 all feature rich metrics dashboard and graph editor - data files
These are the two packages that belong to the OS. 2.6 version of the grafana package does not include the grafana_cli binary.
I would suggest to deinstall the two packages and try to run openhabian installation routine again.
In case that does not work I would do the manual installation. This runs on my installation.
Operation Successful!
Thank you for the help!
Could someone explain how to resolve this in “simple terms” with some instructions?
I have tried a few times and it keeps failing…
You get the same error message that granfan-cli canot be found ?
What is the output of the command
sudo dpkg -l |grep granfana
After a failed install thru openhabian-config
then I did:
sudo apt-get remove grafana 2.6.0
sudo apt-get remove grafana-data 2.6.0
and then installed it again thru openhabian-config and it was successful. Done it twice on different devices…
/David
Thanks for you reply! When I run this I get no output at all?
Thanks @dillunge running those 2 commands appears to have worked as I’m not getting the error anymore! Thanks :slight_smile:
