i have trouble installing openHab 3.0.1 on my Windows 10 pc. I followed the steps on the download page (except step #2 since I think I only need it for programming; please correct me if I’m wrong). When I run the start.bat file the command shell closes after a second and I’ve got the following error in the openhab.log file:
2021-02-23 21:10:47.919 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error occurred while checking the system module.
at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:311)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:87)
at org.eclipse.osgi.internal.framework.EquinoxContainer.(EquinoxContainer.java:68)
at org.eclipse.osgi.launch.Equinox.(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
at org.apache.karaf.main.Main.launch(Main.java:256)
at org.apache.karaf.main.Main.main(Main.java:178)
Caused by: org.osgi.framework.BundleException: Invalid manifest header Export-Package: “org.osgi.dto;version=“1.0”,org.osgi.resource;version=“1.0”,org.osgi.resource.dto;version=“1.0”;uses:=“org.osgi.dto”,org.osgi.framework;version=“1.8”,org.osgi.framework.dto;version=“1.8”;uses:=“org.osgi.dto”,org.osgi.framework.hooks.bundle;version=“1.1”;uses:=“org.osgi.framework”,org.osgi.framework.hooks.resolver;version=“1.0”;uses:=“org.osgi.framework.wiring”,org.osgi.framework.hooks.service;version=“1.1”;uses:=“org.osgi.framework”,org.osgi.framework.hooks.weaving;version=“1.1”;uses:=“org.osgi.framework.wiring”,org.osgi.framework.launch;version=“1.2”;uses:=“org.osgi.framework”,org.osgi.framework.namespace;version=“1.1”;uses:=“org.osgi.resource”,org.osgi.framework.startlevel;version=“1.0”;uses:=“org.osgi.framework”,org.osgi.framework.startlevel.dto;version=“1.0”;uses:=“org.osgi.dto”,org.osgi.framework.wiring;version=“1.2”;uses:=“org.osgi.framework,org.osgi.resource”,org.osgi.framework.wiring.dto;version=“1.2”;uses:=“org.osgi.dto,org.osgi.resource.dto”,org.osgi.service.condpermadmin;version=“1.1.1”;uses:=“org.osgi.framework,org.osgi.service.permissionadmin”,org.osgi.service.packageadmin;version=“1.2”;uses:=“org.osgi.framework”,org.osgi.service.permissionadmin;version=“1.2”,org.osgi.service.resolver;version=“1.0”;uses:=“org.osgi.resource”,org.osgi.service.startlevel;version=“1.1”;uses:=“org.osgi.framework”,org.osgi.service.url;version=“1.0”,org.osgi.util.tracker;version=“1.5.1”;uses:=“org.osgi.framework”,org.apache.karaf.version;version=“4.2.7”,org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version=“4.2.7”,org.apache.karaf.jaas.boot;uses:=“javax.security.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework”;version=“4.2.7”,org.apache.karaf.info;version=“4.2.7”, org.apache.karaf.branding, sun.misc, org.apache.karaf.jaas.boot;uses:=“javax.security.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework”;version=4.2.7, org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version=4.2.7, org.apache.karaf.diagnostic.core;uses:=org.osgi.framework;version=4.2.7, org.apache.karaf.diagnostic.core.common;uses:=org.apache.karaf.diagnostic.core;version=4.2.7”
at org.eclipse.osgi.util.ManifestElement.parseHeader(ManifestElement.java:353)
at org.eclipse.osgi.container.builders.OSGiManifestBuilderFactory.createBuilder(OSGiManifestBuilderFactory.java:85)
at org.eclipse.osgi.storage.Storage.getBuilder(Storage.java:632)
at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:263)
… 6 more
I have installed the Java 11 from Zulu correctly and the command “java -version” prints
openjdk version “11.0.10” 2021-01-19 LTS
OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
OpenJDK 64-Bit Server VM Zulu11.45+27-CA (build 11.0.10+9-LTS, mixed mode)
Thanks in advance for any help!
