Hi all
We have a new awning with a Somfy motor which I control through a Velux KLF 200. The OH2 part works very well, I see the position at 0% when the awning is up and step-by-step going to 100% when the awning is moving down.
I would expect a position of 0% to be called “closed” and the position of 100% to be called “open”.
But in Google Home it’s the other way around which is a bit confusing.
Here’s the item I have defined:
Rollershutter Awning "Awning" <rollershutter> [ "Rollershutter" ] { ga="Awning", inverted="true", channel="velux:rollershutter:95500611:_0:position" }
I found the inverted flag in documentation, but it doesn’t change anything. It’s documented as inverted=true
(without the double quotes) but then the editor is giving me an error: mismatched input 'true' expecting RULE_STRING
Did anyone manage to invert the logic or is the flag used for something else?
