Ive installed openhab directly onto my raspberry pi 3b which is directly connected to my router via ethernet cable. last night I could use the localhost route on my web browser to set up a new account (which i did), but now i can’t even get to the login screen.
Ive tried the obvious off and on process and nothing.
How did you use localhost route. Localhost literally means “this computer”. If you are using openHABian (as suggested by the hostname in your wifi list) there is no browser to to run. If you are on your Mac and brought up the web UI using a localhost:8080 address, that means you installed openHAB on your Mac.
That means the hostname for the machine is openhabian-6 I think.
