Can't login to my openhab
stupid situation but I cant login to my openhab server with ssh.
It says that username and password is incorrect but I didn’t change it.
Is there any way to recover access?
I didnt login for while so I dont know when it could happend.
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: what OS is used and which version
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version:
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
How should we be able to help if you don’t provide the information being asked in your post ???
If it is an openhabian install, user and password is openhabian unless you changed it.
you are right!
I use openhab on rpi4.
Default password was not changed. It seems that username/password are not matching. I receive message that password is incorrect.
Is it any manual workaround to restore default credentials?
In case you have root access you can use the root user to change openhabian user’s password.
In case you don’t have root access you can mount the SD card using e.g. a linux life system or a linux rescue system on an other computer. Then change the password entry in /etc/shadow on the SD card.
If they are not matching any more, the default value is not valid any longer then the password was changed.
Sorry for late answer but modification of file on SD card helped! Thanks a lot!
