Hi everyone,
I have recently started the project of moving from fhem on a raspberry Pi to OpenHAB on my Synology Diskstation. Initial tests with an HTTP bind and switch worked fine so I moved on to integrate my intertechno compatible switches that I switch using a 433Mhz CUL stick.
Thanks to http://www.jadahl.com/ I was able to easily install the necessary drivers and after some trying I am now able to manually switch my switches from the command line. However, I have not been able to get openHAB to recognise my nanoCUL.
I read through what must have been dozens of threads and websites (mostly seeming outdated) and tried the following without any success so far:
- chmod 666 /dev/ttyUSB0
- add the following to openHAB/runtime/bin/setenv
EXTRA_JAVA_OPTS="
-DlibNRJavaSerial.userlib=/volume1/@appstore/openHAB/userdata/tmp/libNRJavaSerial_openhab_0/libNRJavaSerial.so
-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0"
- start openHAB from command line as root
- add user openHAB to the http (and admin) group on the Diskstation
I can only guess that this is a permission or Java issue. However I’m not very experienced with Linux and as such am not sure what else to try. I have attached the openHAB.log below in case anyone around here has the patience to help me out. Any tips would be greatly appreciated.
Thanks in advance
Benjamin
- Platform information:
- Hardware: DS218play (Realtek RTD1296 SoC/1GB)
- OS: DSM 6.2-23739 Update 2
- Java Runtime Environment: openjdk version “1.8.0_161” OpenJDK Runtime Environment (IcedTea 3.7.0) (linux-gnu build 1.8.0_161-b12) OpenJDK 64-Bit Server VM (build 25.161-b12, mixed mode)
- openHAB version: 2.3.0.005
- Issue of the topic: please be detailed explaining your issue
- If logs where generated please post these here using code fences:
23:54:06.176 [DEBUG] [org.openhab.binding.intertechno ] - BundleEvent STARTING - org.openhab.binding.intertechno
23:54:06.180 [DEBUG] [chno.internal.CULIntertechnoActivator] - CULIntertechno binding has been started.
23:54:06.182 [DEBUG] [org.openhab.binding.intertechno ] - BundleEvent STARTED - org.openhab.binding.intertechno
23:54:06.230 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent [unknown:512] - org.openhab.io.transport.cul
23:54:06.234 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTING - org.openhab.io.transport.cul
23:54:06.257 [DEBUG] [openhab.io.transport.cul.CULActivator] - CUL transport has been started.
23:54:06.296 [DEBUG] [.io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl for device type serial
23:54:06.302 [DEBUG] [.io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.network.CULNetworkHandlerImpl for device type network
23:54:06.305 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTED - org.openhab.io.transport.cul
23:54:06.329 [WARN ] [.io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
23:54:06.333 [DEBUG] [org.openhab.binding.intertechno ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={service.id=325, service.bundleid=212, service.scope=bundle, event.topics=openhab/command/*, service.pid=org.openhab.culintertechno, component.name=org.openhab.binding.intertechno.binding, component.id=202} - org.openhab.binding.intertechno
23:54:06.334 [TRACE] [.io.transport.cul.internal.CULManager] - Requesting deviceTypeFactory for type 'serial'
23:54:06.338 [TRACE] [.io.transport.cul.internal.CULManager] - 2 factories registered
23:54:06.338 [DEBUG] [org.openhab.binding.intertechno ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.intertechno.CULIntertechnoBindingProvider}={service.id=324, service.bundleid=212, service.scope=bundle, component.name=org.openhab.binding.intertechno.genericbindingprovider, component.id=203} - org.openhab.binding.intertechno
23:54:06.341 [INFO ] [nternal.serial.CULSerialConfigFactory] - Update config, baudrate = 38400
23:54:06.345 [INFO ] [nternal.serial.CULSerialConfigFactory] - Update config, parity = NONE (0)
23:54:06.347 [TRACE] [techno.internal.CULIntertechnoBinding] - commandON = 00101000101100111111110010010000
23:54:06.349 [TRACE] [techno.internal.CULIntertechnoBinding] - commandOFF = 00101000101100111111110010000000
23:54:06.369 [DEBUG] [.io.transport.cul.internal.CULManager] - Trying to open device serial:/dev/ttyUSB0 in mode SLOW_RF23:54:06.370 [DEBUG] [.io.transport.cul.internal.CULManager] - Searching class for device type serial
23:54:06.428 [DEBUG] [.internal.serial.CULSerialHandlerImpl] - Opening serial CUL connection for /dev/ttyUSB0
23:54:06.557 [WARN ] [.io.transport.cul.CULLifecycleManager] - Can't open CUL
org.openhab.io.transport.cul.CULDeviceException: gnu.io.NoSuchPortException
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:111) [213:org.openhab.io.transport.cul:1.12.0]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.open(AbstractCULHandler.java:163) [213:org.openhab.io.transport.cul:1.12.0]
at org.openhab.io.transport.cul.internal.CULManager.createNewHandler(CULManager.java:150) [213:org.openhab.io.transport.cul:1.12.0]
at org.openhab.io.transport.cul.internal.CULManager.getOpenCULHandler(CULManager.java:85) [213:org.openhab.io.transport.cul:1.12.0]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:86) [213:org.openhab.io.transport.cul:1.12.0]
at org.openhab.io.transport.cul.CULLifecycleManager.config(CULLifecycleManager.java:74) [213:org.openhab.io.transport.cul:1.12.0]
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding.updated(CULIntertechnoBinding.java:147) [212:org.openhab.binding.intertechno:1.12.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [8:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [8:org.apache.felix.configadmin:1.8.16]
Caused by: gnu.io.NoSuchPortException
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) ~[?:?]
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:87) ~[?:?]
... 14 more
23:54:06.609 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=325, bundle=212/mvn:org.openhab.binding/org.openhab.binding.intertechno/1.12.0]: Unexpected problem updating configuration org.openhab.culintertechno
at org.openhab.binding.intertechno.internal.CULIntertechnoBinding$1.open(CULIntertechnoBinding.java:67) [212:org.openhab.binding.intertechno:1.12.0]
at org.openhab.io.transport.cul.CULLifecycleManager.open(CULLifecycleManager.java:92) [213:org.openhab.io.transport.cul:1.12.0]
