Just installed the latest oh2. Trying to pair a new hue hub. Not working. Not seeing the log messages instructing me to press the button on the hub. The page for the oh2 version of this binding doesn’t mention the log messages. Is that still how it’s supposed to work?
UPDATE: tried it a few more times and got the username created, but OH is insisting that the username has not been set in the configuraiton and is forcing the hub’s think offline. I can clearly see the username in the config:
openhab> smarthome:things show hue:bridge:001788a91ea0
UID: hue:bridge:001788a91ea0
Type: hue:bridge
Label: Philips hue (192.168.1.110)
Status: OFFLINE (CONFIGURATION_ERROR): Cannot connect to hue bridge. User name for authentication not available in configuration.
Properties:
vendor : Philips
serialNumber : 001788a91ea0
Configuration parameters:
ipAddress : 192.168.1.110
pollingInterval : 10
sensorPollingInterval : 500
userName : Qodb0MOj3Fya7IpLR1NR0RAgKQi7Ym6WknuyGobP
No channels
openhab>
but in the log I’m seeing this over and over again:
2018-12-18 02:35:32.759 [WARN ] [ue.internal.handler.HueBridgeHandler] - User name for Hue bridge authentication not available in configuration. Setting ThingStatus to offline.
Will continue to troubleshoot, but if anyone else has seen and fixed this, I’d love to know how you did it.
UPDATE 2: This just started working. I’ve done some fiddling in the karaf console and a few reboots. Not sure what thing fixed it. Maybe the second reboot?
