My OH2 setup is acting a bit crazy these days. I added a Z-Wave Aeon Stick 5 and a Multisensor 6, and after that it’s been acting up. Works well for about 24 hours, then I can’t access serverip:8080 OR SSH to :8101 to check KARAF. However, normal SSH to serverip:15 is working as it should so I can do a reboot from there. After rebooting it works great.
Any ideas on what this could be, or how to debug this? Can’t see anything in logs that should lead to any issues…
Ok, been searching a lot on this topic, and seems I’m the only one experiencing this. Anybody have any ideas? This started after I connected a Z-stick and a Multisensor 6, so I’m a bit curious to if this is a Z-wave issue. Anything you have encountered before @chris ? (I understand you are the z-wave guru).
I see from the log that there are sometimes some sending errors, but they are few and random. Probably due to placement, but I can’t understand that that should “kill” my server over time…
Thanks for the feedback @Chris. As a trial I left my server running last night without the stick and now it’s down again…
Any ideas on how I can check what process has “killed” the server upon reboot? I take it there should be some OH log that explains what has gone wrong.
Strangely enough, I can open a new ssh connection and ping the server, but the UI doesn’t work so it seems the process has just stopped somehow…
