This was discussedhere but hasn’t seemed to be resolved.
I would like to upgrade from 2.0, but if I do, I get an error of “Unable to create a system terminal, creating a dumb terminal” when starting manually or via LaunchDaemon on 2.2. Version 2.1 does work, but then there are issues with the Astro binding on it.
I am using an i5 Mac Mini with 8GB ram, so there shouldn’t be any issues with hardware.
I have written a small bash script, that restarts openhab when it exits. This script is started via the screen utility, but this is just a crude workaround for the time I was on vacation.
That is really very simple, I just added an infinite loop around the openhab start command:
while true; do
echo "Launching the openHAB runtime..."
export OPENHAB_HTTP_PORT=9180
export OPENHAB_HTTPS_PORT=9143
export EXTRA_JAVA_OPTS=""
DIRNAME=`dirname "$0"`
exec "${DIRNAME}/runtime/bin/karaf" "${@}"
echo "openHAB exited, restarting in 10s..."
sleep 10
done
I added the “sleep 10” at the end to give ma a chance to interrupt the loop. This could be solved much more sophisticated but I was in a hurry before an vacation, beside that I still hope, that the issue with starting openhab via launchd will be solved.
