And now - I can using phisical button on sonoff turn it on / off which cause changing value of soffth1603_relay2 in Basic UI so that part of config is correct and receiving mqtt connection is ok. Using soffth1603_switch from Basic UI I can also change soffth1603_relay2 value on Basic UI BUT it can not turning on / off my sonoff . It looks like mqtt binding dont send command to device … . Or maybe mosquitto config needs to be corrected … ?
What firmware are you using with the Sonoff? Are you certain you have the right topics? Given the topic names I would guess that you need to use sonoff1603/RelayState/Command or something like that to actually command the relay.
The fact that your relay2 Item is working shows that your MQTT config is correct.
