I’ve got a z-wave mini plug outlet, MP21Z. I’ve added a thing for it and set the switch channel to an item. On one page I’m trying to set up a toggle card that will switch it on or off. But I don’t see the switch in the list at all. I know I’ve done this before so I guess I’m forgetting a step somewhere. But I haven’t found the missing step in an hour or so of working through the problem. When I look in the Model I can see the thing and the switch channel. Turning it on and off from there works. Manually turning it on or off shows up in the event log.
openhab> things list | grep SV
zwave:device:wopr:node44 (Type=Thing, Status=ONLINE, Label=SV07 Plug, Bridge=zwave:serial_zstick:wopr)
openhab> items list | grep SV
SV07_Plug_Switch (Type=SwitchItem, State=NULL, Label=Switch, Category=Switch, Tags=[Point])
The thing is there, I linked the switch channel and can control the outlet through the web UI, but I never see the item when configuring the toggle card on a layout page.
